Discuss
Washer won't spin
 in
Washer Repair
I have this washer machine that seems to work in all cycles.....except for the spinning of the drum. The
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't spin
  #1 (permalink)
Old 11-01-2007, 09:25 PM
madmanracing11 madmanracing11 is offline
Junior Member
madmanracing11 is on a distinguished road
Default Washer won't spin
Model Number: 110.23832100   Brand: Kenmore   Age: 5 - 10 years
I have this washer machine that seems to work in all cycles.....except for the spinning of the drum. The motor runs. The timer seems to advance. The water fills and drains. Any ideas for me? I'd like to diagnose the problem and fix it if possible.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-01-2007, 10:56 PM
Laurence23 Laurence23 is offline
Junior Member
Laurence23 is on a distinguished road
Default
read my thread see if that helps you
  #3 (permalink)
Old 11-02-2007, 05:35 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Remove panel screws and tilt back, now remove outer cover of washer,remove pump and motor.
Turn tranny coupler clockwise till drum turns. If very hard to turn you either have dragging brake shoes, or something stuck in the tub.
If easy to turn, you have a worn out clutch or bad spin basket drive block.
Please post results.
__________________
  #4 (permalink)
Old 11-21-2007, 08:00 AM
peterb peterb is offline
Junior Member
peterb is on a distinguished road
Default Remove top of Kenmore washer
How do you remove the top of a Kenmore washer?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer will not spin chevy2 Washer Repair 6 03-10-2008 01:47 PM
GE washer will not spin csol147462 Washer Repair 9 11-09-2007 07:14 PM
Washer will not spin Darren Washer Repair 4 10-26-2007 02:41 PM
washer won't spin Craig Washer Repair 1 09-30-2007 09:33 PM
Washer does not spin Bill Noonan Washer Repair 0 09-12-2007 06:46 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
