washer makes noise in spin cycle, the noise is coming from bottom of washer there is two bearings in the bottom, is there anyway to find out what bearing is making noise.
Look and see if there is any evidence of water leaking from the tub, and/or being splattered inside the cabinet. The most likely culprit is the tub bearing. When you replace it you will also want to replace the stem kit and boot seal. The job takes a pro about 40 minutes to complete.
no water leaking, the noise is coming from the base of the washer where the pulley is, i looked at the drawing of the parts there is a brake bearing and a ball bearing in the housing one of these bearings is making a noise.
