Washer works fine until it reaches the spin cycle. I tried all the settings on the timer, still no spin. Motor was replaced about 6 months ago. Searched this forum and went through the brake, clutch, drive coupler and checked the tub for a jam. All seems good. Once the timer reaches spin, the motor hums loudly, then the thermal switch kicks out. I spun the motor by hand thinking it might have a dead spot, but no go. Problem originally seemed intermittent, but now appears constant. What next?
I would do the tranny coupler test in my sticky, "replacing direct drive washer brake shoes", seems like you have jammed brake shoes.
Thanks for getting back to me. I checked the brake shoes, nothing worn or ugly. Took the assembly apart, cleaned and lubed everything with the same no spin results.
I would pull the cover off the timer and check, probably bad/ burnt contacts, AP2907903.
Good call. Pulled the timer, opened it up and got the contact block out. Carefully, I opened each contact and found 2 burned and ugly. I assume since you posted the PN for the timer, the contact block isn't available separately? Thanks
No parts available for the timer. I would replace the timer as it probably got damaged by the old motor.
Changed the timer, still have the same problem. Now what?
Did you check the lid switch?
Check the timer plug, could have a burnt wire.
