| » Washer gives F50 code |
Model Number: wtw6200sw0 Brand: Whirlpool Age: 5 - 10 years
Washer begins to fill normally but after approx 1-2 minutes F50 code appears. Clear code by pressing pause then start and same thing happens again. This happens on any cyles setting, size, etc.
Manual says "call a technician". Any ideas? Ads By Google Related Models |
Quote:
The F 50 code indicates the control board, is not seeing the proper rotation RPM from the motor control, First thing to do is check and make sure the inner wash tub moves freely, open the lid and turn the tub by hand, listen closely for a drag sound if it doesn't move very well (something stuck under, or between the tubs). Start the washer (empty) and make sure the inner tub has raised(floated up) approximately 3/8 " and has cleared the tub drive block when the code appears. Your technical date sheet, is located on the inside of the front panel, you'll need to raise the top of the machine, (use a putty knife and push in on the two spring clips holding the top down on the cabinet front) and you can run the test modes and diagnostic tests. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| 1E code on my LG Washer | Fordsblue | Washer Repair | 7 | 11-04-2012 08:12 PM |
| code 5d on HE2 washer | Geomorph | Washer Repair | 1 | 11-19-2010 04:48 PM |
| Washer gets F06 code | handyman0357 | Washer Repair | 7 | 08-10-2010 06:20 AM |
| Washer has code DN | Bethaney | Washer Repair | 1 | 07-27-2010 06:59 AM |
| washer code F 28 | hodgetheman | Washer Repair | 1 | 10-11-2009 05:55 PM |
