| » Washer Intermittently Spins Correctly |
Model Number: GSQ9669LW1 Brand: Whirlpool Age: 5 - 10 years
I have a Whirlpool Gold Ultimate Care II, Super Capacity Plus Washer, model #GSQ9669LW0 that spins correctly at times but quite often does not spin. The motor continues to run following pumping but never stops before going into the spin cycle and the tub does not spin. If this happens for too long it gets a hot smell. A repairman came and said it was the neutral drain transmission and was going to check the price for the entire transmission. I haven't heard back from him in 3 weeks. After reading some of the posts online, I'm not sure if I need the transmission or just the neutral drain part. There is a circle of black debris on the floor under the washer too so I'm also not sure if it could be the clutch. Any help or advice would be greatly appreciated as I really like my machine, which looks brand new although it's 7 years old. I prefer to repair it if it's not too expensive as I do not like the newer models as much. Thanks.
Quote:
There's a lot going on there, I'm thinking you most likely have a bad clutch assembly, based on your post. Part number: AP3094537 And you will want to check or replace the motor coupling assembly, as well Part number: AP3963893 These are more common problems, than a bad neutral drain lever or bad transmission, Here's a good informative post from our Repair Forum, it will give you a lot of information and get you on the way to repairing the washer. Replacing direct drive washer brake shoes Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Whirlpool Spins Intermittently | bordercity | Washer Repair | 7 | 01-12-2011 10:00 AM |
| hirlpool washer wont spin correctly(spins very slow) | jre72 | Washer Repair | 1 | 08-21-2009 06:08 AM |
| Drum spins intermittently | rnhowie | Dryer Repair | 9 | 05-25-2009 05:02 PM |
| Kenmore Spins Intermittently | Philn | Washer Repair | 5 | 01-26-2009 05:40 AM |
| Washer spins intermittently | wardtrevor | Washer Repair | 1 | 03-30-2008 04:07 AM |
