Discuss
Control Panel
 in
Washer Repair
How do you open the control panel on a Roper machine? Thanks Ads By Google
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Control Panel
  #1 (permalink)
Old 04-25-2011, 07:06 AM
Junior Member
stappa is on a distinguished road
Default Control Panel
Brand: Roper   Age: 1 - 5 years
Ads By Google
  #2 (permalink)
Old 04-26-2011, 05:22 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Normall you remove the two screws at each end that hold it on (they may be behind trim which snaps off). Some newer models may require releasing clips by sliding a stiff putty knife under the end pieces from the front.
If you need more info please post a full model number so we can see which Roper you have.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Need help removing control panel and front panel to get at the drain pump jthenne Washer Repair 2 02-16-2011 02:15 PM
No Display Troubleshooting: Control Panel Assy or Electronic Clock Control Board hddman Oven Repair (including Ranges and Cooktops) 0 04-26-2010 12:09 PM
Control Panel or Electronic Control - which causes blinking panel lights? MarcLCH Dishwasher Repair 1 02-25-2010 03:25 AM
tranformer blew on control panel need specs for new transformer not control panel kaydog2009 Oven Repair (including Ranges and Cooktops) 0 05-11-2009 07:22 AM
Replace control panel or just control panel housing? Max Strano Dishwasher Repair 1 08-26-2008 06:02 PM
