| » Whirlpool cabrio washer stops stall at 17 minutes left in cycle |
Model Number: wtw6300swd Brand: Whirlpool Age: 1 - 5 years
I was having problems with my washer stalling with 17 minutes left in cycle and running on that cycle for like 20 minutes sometimes. I read if could be the control board so i bought one from here and replaced it and it still does the same thing. I was wondering if there is any other reason it would be doing this. I am sure everything is hooked up right and checked everything and it all looks good to me. If anyone has any helpfull ideas would love to hear them.
The electronics on this model are a mess, to put it mildly.
Here is a link to the service manual for your model, https://secured.whirlpool.com/Servic...LE/8178583.pdf Use it to generate the built in diagnostics to see if they can give you any clues. Click on your model number to see exploded views of your control panel, and notice that you have more than one electronic component. Don't know which one you replaced, but try the other one. Remember you can return the parts if you do not need them.
__________________
I have the exact same problem at 17 minutes, and read on another forum that maybe the drain hose was too long and was siphoning water from the washer as it sat there, and the suggestion was to raise the hose so it was higher than the washer. Sounded plausible, but it didn't help.
Here's what I do now - wash every load on the "Quick Wash" cycle. You have to adjust temps and spin speeds etc, but at least it always makes it through a complete cycle every time. And "Quick Wash" is only a few minutes shorter than a regular cycle, so I feel like everything's getting adequately clean. |
| Display Modes | |
| Cabrio Washer stops 1 min into cycle F-51 fault | tvezdos | Washer Repair | 2 | 05-08-2012 06:52 PM |
| washer shuts off with 6 minutes left on timer | sandranorred | Washer Repair | 7 | 12-10-2009 11:11 AM |
| Spin Cycle Stops @ 7 Minutes (no Error Code) | jacksouix | Washer Repair | 4 | 09-02-2009 06:39 PM |
| Whirlpool dryer stops after a few minutes | ranrog | Dryer Repair | 2 | 07-01-2009 08:19 PM |
| wash cycle stops 10 minutes after start | fullhouse | Washer Repair | 1 | 03-20-2008 04:46 PM |
