Water pump works--agitator turns about 1 rpm --no spin-- coupler between motor and trans intact --clutch looks to be good--I have had clutch band out--shaft out of trans very hard to turn but I don't know if it should be hard or easy--is it okay to take cover off trans body because no gasket is listed by Sears--I had thought clutch was bad but now I don't know what to replace
