Discuss
Whirlpool froze up
 in
Washer Repair
I bought this machine used 3 years ago for $150. My renters said the washer made a load squeaking noise
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool froze up
  #1 (permalink)
Old 10-31-2007, 06:47 PM
johnd johnd is offline
Junior Member
johnd is on a distinguished road
Default Whirlpool froze up
Model Number: LXR7144EQ1   Brand: Whirlpool   Age: 5 - 10 years
I bought this machine used 3 years ago for $150. My renters said the washer made a load squeaking noise then wouldn't do anything except empty the water. I looked at it today, The basket seems as if it is no longer connected to whatever holds it centered (it moves very far to each side and does not spin on an axis). I though it might be a broken belt and looked at the workings by tipping it on its side. To my dismay, it does not seem to use belts. Any obvious things that go wrong with the direct drive in these machines? Is this machine a good enough washer to make it worthwhile to repair or is it just a cheap washer that I should replace?
Thanks,
John
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-01-2007, 04:03 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Remove agitator and check the spin basket drive block, probably came loose.It is a right hand thread, so just turn it clockwise.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
