Discuss
80 Series washer only fills with hot water
 in
Washer Repair
I have a Kenmore 80 series washer and it filled fine for the wash but when it was time for
Appliance Repair Forum > Appliance Repair Help > Washer Repair » 80 Series washer only fills with hot water
  #1 (permalink)
Old 04-21-2011, 03:49 PM
Junior Member
sandyb is on a distinguished road
Default 80 Series washer only fills with hot water
Model Number: 11026826190   Brand: Kenmore   Age: More than 10 years
I have a Kenmore 80 series washer and it filled fine for the wash but when it was time for the rinse, the cold water only trickled in. I removed the hoses and checked the pressure and they are both fine. I hooked the hot water to the cold inlet and it still only trickles in. I checked the filters on the intake on the back of washer and they appear to be fine. What should I do now?
Related Models
Kenmore 11026832690 AUTOMATIC WASHER
Kenmore 11026832691 AUTOMATIC WASHER
Kenmore 11026832692 AUTOMATIC WASHER
Kenmore 11026832694 AUTOMATIC WASHER
Kenmore 11026834690 WASHER
Kenmore 11026834691 AUTOMATIC WASHER
Kenmore 11026834692 AUTOMATIC WASHER
Kenmore 11026834694 AUTOMATIC WASHER
Kenmore 11026842690 WASHER
Kenmore 11026842691 AUTOMATIC WASHER
Kenmore 11026842692 AUTOMATIC WAHSER
Kenmore 11026842694 AUTOMATIC WASHER
Kenmore 11026844690 WASHER
Kenmore 11026844691 AUTOMATIC WASHER
Kenmore 11026844692 AUTOMATIC WAHSER
Kenmore 11026844694 AUTOMATIC WASHER
Kenmore 11026852500 WASHER
Kenmore 11026852501 RESIDENTIAL WASHER
Kenmore 11026852502 WASHER
Kenmore 11026852503 WASHER
Kenmore 11026852504 RESIDENTIAL WASHER
Kenmore 11026862500 WASHER
Kenmore 11026862501 WASHER
Kenmore 11026862502 WASHER
Kenmore 11026862503 RESIDENTIAL WASHER
Kenmore 11026882500 WASHER
Kenmore 11026882501 WASHER
Kenmore 11026882502 WASHER
Kenmore 11026882503 RESIDENTIAL WASHER
Kenmore 11026884500 WASHER
Kenmore 11026884501 WASHER
Kenmore 11026884502 WASHER
Kenmore 11026884503 RESIDENTIAL WASHER
Kenmore 11026892690 TB26-10- WARM RINSE
Kenmore 11026892691 AUTOMATIC WASHER
Kenmore 11026894691 AUTOMATIC WASHER
Kenmore 11026901690 SUPER CAPACITY PLUS AUTOMATIC WASHER
Kenmore 11026901691 AUTOMATIC WASHER
Kenmore 11026901692 AUTOMATIC WASHER
Kenmore 11026902690 AUTOMATIC WASHER
Kenmore 11026902691 WASHER
Kenmore 11026902692 AUTOMATIC WASHER
Kenmore 11026904691 AUTOMATIC WASHER
Kenmore 11026904692 AUTOMATIC WASHER
Kenmore 11026912690 AUTOMATIC WASHER
Kenmore 11026912691 AUTOMATIC WASHER
Kenmore 11026914690 WASHER
Kenmore 11026914691 AUTOMATIC WASHER
Kenmore 11026922500 WASHER
Kenmore 11026922501 WASHER
Kenmore 11026922502 WASHER
Kenmore 11026922503 RESIDENTIAL WASHERS
Kenmore 11026924500 WASHER
Kenmore 11026924501 WASHER
Kenmore 11026924502 WASHER
Kenmore 11026924503 RESIDENTIAL WASHERS
Kenmore 11026932690 Residential Washers
Kenmore 11026932691 Residential Washers
Kenmore 11026934690 Residential Washers
Kenmore 11026934691 Residential Washers
Kenmore 11026942500 WASHER
Kenmore 11026942501 WASHER
Kenmore 11026942502 WASHER
Kenmore 11026942503 RESIDENTIAL WASHERS
Kenmore 11026944500 WASHER
Kenmore 11026944501 WASHER
Kenmore 11026944502 WASHER
Kenmore 11026944503 RESIDENTIAL WASHERS
Kenmore 11026952690 AUTOMATIC WASHER
Kenmore 11026952691 AUTOMATIC WASHER
Kenmore 11026954690 AUTOMATIC WASHER
Kenmore 11026954691 AUTOMATIC WASHER
Kenmore 11026955690 AUTOMATIC WASHER
Kenmore 11026955691 AUTOMATIC WASHER
Kenmore 11026962500 WASHER
Kenmore 11026962501 WASHER
Kenmore 11026962502 WASHER
Kenmore 11026962503 RESIDENTIAL WASHERS
Kenmore 11026964500 WASHER
Kenmore 11026964501 RESIDENTIAL WASHER
Kenmore 11026964502 WASHER
Kenmore 11026964503 RESIDENTIAL WASHERS
Kenmore 11026966500 RESIDENTIAL WASHER
Kenmore 11027032600 WASHER
Kenmore 11027032601 AUTOMATIC WASHER
Kenmore 11027032602 RESIDENTIAL WASHER
Kenmore 11027032603 RESIDENTIAL WASHER
Kenmore 11027042600 WASHER
Kenmore 11027042601 RESIDENTIAL WASHERS
Kenmore 11027042602 RESIDENTIAL WASHER
Kenmore 11027042603 RESIDENTIAL WASHER
Kenmore 11027052600 RESIDENTIAL WASHERS
Kenmore 11027052601 RESIDENTIAL WASHER
Kenmore 11027052602 RESIDENTIAL WASHER
Kenmore 11027062600 WASHER
Kenmore 11027062601 RESIDENTIAL WASHER
Kenmore 11027062602 RESIDENTIAL WASHER
Kenmore 11027062603 RESIDENTIAL WASHER
Kenmore 11027062604 RESIDENTIAL WASHER
Kenmore 11027072600 WASHER
Kenmore 11027072601 RESIDENTIAL WASHER
Kenmore 11027072602 RESIDENTIAL WASHER
Kenmore 11027072603 RESIDENTIAL WASHER
Kenmore 11027072604 RESIDENTIAL WASHER
Kenmore 11027082600 RESIDENTIAL WASHER
Kenmore 11027082601 RESIDENTIAL WASHER
Kenmore 11027082602 RESIDENTIAL WASHER
Kenmore 11027082603 WASHER
Kenmore 11027082604 RESIDENTIAL WASHER
Kenmore 11027082605 RESIDENTIAL WASHER
Kenmore 11027086601 RESIDENTIAL WASHER
Kenmore 11027086602 RESIDENTIAL WASHER
Kenmore 11027086603 RESIDENTIAL WASHER
Kenmore 11027086604 RESIDENTIAL WASHER
Kenmore 11027086605 RESIDENTIAL WASHER
Kenmore 11027087600 RESIDENTIAL WASHER
Kenmore 11027087601 RESIDENTIAL WASHER
Kenmore 11027087602 RESIDENTIAL WASHER
Kenmore 11027087603 RESIDENTIAL WASHER
Kenmore 11027087604 RESIDENTIAL WASHER
  #2 (permalink)
Old 04-22-2011, 07:59 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Check to see that you are getting 120v to the cold water solenoid. If so, try replacing the water valve assembly.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer fills with water by itself michele1234 Washer Repair 8 09-20-2015 04:05 PM
washer fills with water when off hidon Dishwasher Repair 1 05-29-2010 04:56 AM
washer kenmore 80 series top loader fills with water wont drain agitate or spin out dwills Washer Repair 0 05-27-2010 10:24 PM
Washer fills with water when OFF tballard Washer Repair 2 03-01-2010 08:43 AM
Washer fills with water and then nothing mamabotanica Washer Repair 1 08-06-2009 10:32 AM
