| » Maytag Ensignia Washer wont spin |
Model Number: MAV8557 Brand: Maytag Age: 1 - 5 years
Can anyone give me some insight on why my washer wont spin out. Everything else seems to be working fine. The lid switch seems to check ok using the wiring schematic supplied with the machine.
Quote:
Howorth, You didn't mention, wether the motor is running in the spin cycle. As long as the motor is running and the washer drains in the spin cycle, you need to check : The motor and slide plate assembly, make sure the motor slides free and easy. Check the belt and pulleys (3) for excessive wear and tear. If all is OK, repalce the Thrust Bearing Kit (follow the instructions carefully), Part number: AP4009132 That's the most common failure for this style washer with spin problems. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| maytag ensignia wont aggitate or spun | apippw | Washer Repair | 1 | 03-02-2011 04:27 PM |
| Maytag Ensignia Spin Problems | elmo706 | Washer Repair | 1 | 01-09-2010 02:45 PM |
| Maytag Ensignia wont sensor dry | treeforest | Dryer Repair | 7 | 08-11-2009 06:53 AM |
| Maytag (Ensignia)washer won't spin | jaminmills | Washer Repair | 0 | 09-06-2008 08:22 PM |
| Maytag (Ensignia)washer won't spin | Myra | Washer Repair | 2 | 10-08-2007 07:29 AM |
