drdavid
#1 Posted : Thursday, April 21, 2011 6:56:36 AM(UTC)
drdavid
door is stuck in lock condition...f22 fault on display;;;;;is there anyway to open without breaking open thanks
Joe / APP Team
#2 Posted : Thursday, April 21, 2011 8:54:41 AM(UTC)
Joe / APP Team
Dave , there are two methods of manually unlocking the loading door latch assembly.
We're sending both, just in case.
Good Luck,
#1
Manually Unlocking the Door Lock System
1. Unplug washer or disconnect power.
2. Remove the lower kick panel.
3. Reach up along the inside of the front and locate the
bottom of the door switch/lock unit.
4. Located on the bottom of the door switch/lock unit is a
tear-drop shaped tab.
5. Gently pull the tab down about a ¼" or until a click is
heard.
6. The door may be opened.
#2
1.
2. Remove the top washer panel.
3. Reach down along the inside of the front (between tub and CCU) and locate the top of the door switch/lock assembly.
4. Located on the top of the door switch/lock assembly is a ring-shaped tab.
5. Gently pull the tab upward about ¼" or until a click is heard.
KitchenAid freezer door stuck (Refrigerator & Freezer Repair)
by willeaton Today at 7:31:34 AM(UTC)
Frontloader Door stuck shut (Washer Repair)
by KnatFixes 9/12/2013 6:55:21 AM(UTC)
roper dishwasher rud4500 soap door stuck shut (Dishwasher Repair)
by jbgorecom 9/6/2013 8:15:05 AM(UTC)
Damper door stuck shut (Refrigerator & Freezer Repair)
by motox92 6/16/2013 11:17:25 AM(UTC)
Kitchen Aid Oven door stuck locked (Oven Repair (including Ranges and Cooktops))
by bert156 6/14/2012 8:54:11 AM(UTC)
Broken door clamp-door stuck closed (Microwave Repair)
by tampafl 5/16/2012 9:19:43 AM(UTC)
door stuck (Washer Repair)
by drdavid 4/21/2011 7:03:46 AM(UTC)
gas stove door stuck shut with error codes (Oven Repair (including Ranges and Cooktops))
by Stoves 2/4/2011 8:18:01 AM(UTC)
GE Washer door stuck on lock (Washer Repair)
by GEWasher24 1/30/2011 12:05:31 PM(UTC)
GE Door Stuck - autolock? (Dishwasher Repair)
by personalt 3/12/2009 5:33:53 AM(UTC)
door stuck closed with broken linkage to interlock (Microwave Repair)
by bloomerang 1/15/2009 5:06:00 AM(UTC)
Front Load Washer Door Stuck (Washer Repair)
by GlennaA 7/11/2008 6:56:03 AM(UTC)
