Discuss
Kenmore front loader won't spin
 in
Washer Repair
My washer will not spin at all. It worked fine on one load & then the next load…no spin at
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore front loader won't spin
  #1 (permalink)
Old 04-20-2011, 06:06 PM
Junior Member
71bob71 is on a distinguished road
Default Kenmore front loader won't spin
Model Number: 417.29052991   Brand: Kenmore   Age: 5 - 10 years
My washer will not spin at all. It worked fine on one load & then the next load…no spin at all.
I went through the diagnostic procedure in the paperwork that came with the washer & concluded the motor thermal cutout was not working (no voltage at pins 2 & 4 in the four pin connector). Since the thermal cut out is inside the motor, I removed the motor to check it. The cutout checked out fine, but I noticed that one brush was completely worn out. Since two new brushes cost almost the same as a new motor, I just bought a new motor. I installed it & it still won’t spin.
Why would there be no voltage between pins 2 & 4 if the cutout was OK? By the way, the diagnostic procedure doesn’t say a word about whether to check the voltage at the connector or at the block it plugs in to. No matter, there was no voltage at either place.
So, I have 110V at the wall, 110V into the washer & no voltage at pins 2 & 4. What should I check next?
By the way, it looks like the Frigidaire service tips website Electrolux Major Appliances Service Website is not available anymore? Clicking on it takes me to a Login screen that I obviously don’t have a login for. Is the service manual available anywhere else?
Related Models
Kenmore 41715644 OUTDOOR GRILL
Kenmore 41724182300 WASHER
Kenmore 41724182301 WASHER
Kenmore 41727182700 WASHER
Kenmore 41727182701 WASHER
Kenmore 41727182702 WASHER
Kenmore 41727182703 WASHER
Kenmore 41727182704 WASHER
Kenmore 41729022890 FREESTANDING WASHER
Kenmore 41729042990 FRONTLOAD WASHER
Kenmore 41729042991 KENMORE WASHER
Kenmore 41729042992 FRONT LOAD WASHER
Kenmore 41729052990 KENMORE WASHER
Kenmore 41729052991 WASHER
Frigidaire 41739012890 Frg(v0) / Washer
Kenmore 41739012890 STACK WASHER
Kenmore 41739012891 WASHER
Frigidaire 41739012891 WASHER
Frigidaire 41739022890 Frg(v0) / Washer
Kenmore 41739022891 WASHER
Frigidaire 41739022891 Frg/washer
Kenmore 41740032990 WASHER
Kenmore 41740042990 WASHER
Kenmore 41740052990 WASHER
Kenmore 41740142000 WASHER
Kenmore 41740412700 WASHER
Kenmore 41740412701 WASHER
Kenmore 41740412702 SEARS/FRONT LOAD WASHER -0582
Kenmore 41740412703 WASHER
Kenmore 41741042000 WASHER
Kenmore 41741052000 FRONTLOAD WASHER
Kenmore 41741100000 WASHER
Kenmore 41741101000 WASHER
Kenmore 41741102000 WASHER
Kenmore 41741142000 RESIDENTIAL WASHER
Kenmore 41742042100 WASHER
Kenmore 41742052100 WASHER
Kenmore 41742142100 WASHER
Kenmore 41743042200 SEARS/FRONTLOAD WASHER
Kenmore 41743042300 WASHER
Kenmore 41743052200 SEARS/FRONTLOAD WASHER
Kenmore 41743142200 SEARS/FRONTLOAD WASHER
Kenmore 41743142300 WASHER
Kenmore 41744042400 WASHER
Kenmore 41744052400 WASHER
Kenmore 41744052401 WASHER
Kenmore 41744052500 WASHER
Kenmore 41744072300 WASHER
Kenmore 41744082400 WASHER
Kenmore 41744082500 WASHER
Kenmore 41744092500 WASHER
Kenmore 41744102300 WASHER
Kenmore 41744102301 WASHER
Kenmore 41744130000 WASHER
Kenmore 41744131000 WASHER
Kenmore 41744132000 WASHER
Kenmore 41744142400 WASHER
Kenmore 41744152400 WASHER
Kenmore 41744152401 WASHER
Kenmore 41744152500 WASHER
Kenmore 41744252500 WASHER
Kenmore 41744252501 WASHER
Kenmore 41747102700 WASHER
Kenmore 41747102701 WASHER
Kenmore 41748102700 WASHER
Kenmore 41748102701 WASHER
Kenmore 41748106700 WASHER
Kenmore 41748112700 WASHER
Kenmore 41748112701 WASHER
Kenmore 41748116700 WASHER
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Kenmore 41759012890 GAS DRYER
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41759022890 GAS DRYER
Kenmore 41764182300 ELECTRIC DRYER
Kenmore 41769042990 KENMORE DRYER
Kenmore 41769042991 DRYER
Kenmore 41769052990 DRYER
Kenmore 41769052991 ELECTRIC DRYER
Kenmore 41774182300 GAS DRYER
Kenmore 41774182301 GAS DRYER
Kenmore 41779042990 DRYER
Kenmore 41779042991 DRYER
Kenmore 41779052990 DRYER
Kenmore 41779052991 DRYER
Kenmore 41780032990 DRYER
Kenmore 41780042990 DRYER
Kenmore 41780042991 DRYER
Kenmore 41780052990 DRYER
Kenmore 41780052991 DRYER
Kenmore 41780142000 DRYER
Kenmore 41780412700 DRYER
Kenmore 41781042000 DRYER
Kenmore 41781042001 DRYER
Kenmore 41781052000 ELECTRIC DRYER
Kenmore 41781052001 DRYER
Kenmore 41781100000 DRYER
Kenmore 41781101000 DRYER
Kenmore 41781102000 DRYER
Kenmore 41781142000 DRYER
Kenmore 41781142001 DRYER
Kenmore 41782042100 DRYER
Kenmore 41782042101 DRYER
Kenmore 41782042102 SEARS/DRYER
Kenmore 41782052100 DRYER
Kenmore 41782052101 DRYER
Kenmore 41782052102 DRYER
Kenmore 41782052103 SEARS/ELECTRIC DRYER
Kenmore 41782142100 DRYER
Kenmore 41782142101 DRYER
Kenmore 41782142102 SEARS/ELECTRIC DRYER
Kenmore 41783042200 SEARS/DRYER
Kenmore 41783042201 SEARS/ELECTRIC DRYER
Kenmore 41783042300 DRYER
Kenmore 41783052200 SEARS/DRYER
Kenmore 41783052201 SEARS/DRYER
Kenmore 41783142200 SEARS/DRYER
Kenmore 41783142201 SEARS/ELECTRIC DRYER
  #2 (permalink)
Old 04-22-2011, 11:47 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Here is a link to a service manual for your model. Use the troubleshooting diagrams and be sure and check the speed/motor control board and the door lock assembly. Those are the two weak points on this model, and one of them is a likely source of your problem.
http://www.emaservicetips.com/pdfs/3...ionWashers.pdf
__________________
  #3 (permalink)
Old 04-22-2011, 06:40 PM
Junior Member
Default
Well, laundry is again getting washed in my house.
Thanks for the reply, Sid, the link to the service manual was the key.
I studied the troubleshooting pages & realized one small detail that made all the difference. Previously, from reading the owner's manual, I thought the drum was supposed to turn a bit when the washer was first started & was filling with water, so after replacing the motor I just started the washer up to see if it would turn. I didn't realize that the drum wouldn't turn until after it was finished filling. So, I tried it again & this time I just let it fill all the way & then waited to see if it would turn. This time it worked, of course.
So it was the motor & its worn out brushes that were the problem after all.
Thanks again -
  #4 (permalink)
Old 04-22-2011, 06:43 PM
Senior Expert
APP Volunteer
Default
Well really glad you were able to figure it out, and thanks for the update which will help a lot of the readers here.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Front Loader:Won't spin and now won't drain Sweetpeach Washer Repair 0 05-03-2010 04:42 AM
Kenmore Front Loader:Won't spin and now won't drain Sweetpeach Washer Repair 0 05-03-2010 04:39 AM
kenmore front loader will not spin max-blake Washer Repair 4 04-10-2010 02:04 PM
Kenmore front loader washer won’t spin Bob Watts Washer Repair 7 05-23-2009 03:30 PM
Kenmore Front Loader wont spin corrales Washer Repair 3 05-16-2009 06:55 AM
