Hi
I have been searching the treads and can't find my answer. I have a GE Front load that won't spin. It fills, it drains. I have, once and a while, during the repair, had the motor run on low speed. I have the brushes out now and 1 is really worn. I have replaced the timer and that did not fix the problem. I get weird readings when I follow the troubleshooting guide. Any help would be very helpful.
Thank You Lemon
