Discuss
FAV6800AWW Clutch Issue - Signs of Water Leak
 in
Washer Repair
I have a Maytag Neptune Model FAV6800AWW, Serial # starts with "16". Per other topics on this forum, there were
Appliance Repair Forum > Appliance Repair Help > Washer Repair » FAV6800AWW Clutch Issue - Signs of Water Leak
  #1 (permalink)
Old 04-18-2011, 07:11 AM
Junior Member
4MMsDad is on a distinguished road
Default FAV6800AWW Clutch Issue - Signs of Water Leak
Model Number: FAV6800AWW   Brand: Maytag   Age: 5 - 10 years
I have a Maytag Neptune Model FAV6800AWW, Serial # starts with "16". Per other topics on this forum, there were issues with the Off-balance indicator during spin. I removed the clutch and found the steel pin at the end of the spring to be moving freely within the clutch, so I need to request a new clutch. Question # 1 is do I need to order the full assembly (AP4009131) or do I only need the clutch (AP4310552).
Also, a secondary question. When taking the clutch apart, I noticed that the bearings were very rusty and completely locked-up. Even though the spring had an issue, I lubed the clutch with WD-40 and it took some work to get this to move again. The rust seemed a bit curious to me. I noticed a lot of white powder in the clutch as well (sign of water previously). After I pulled the clutch apart, I realized that I had not run the drain cycle completely and there was water still in the tub. I then noticed a small drip coming from the bottom of the tub around the area where the clutch is attached. I'm wondering now if part of the problem wasn't simply the age of the clutch but the fact that there's minor water penetration occurring, which caused rusting and other build-up. Does water normally drip from this location or this is a secondary issue that needs to now be addressed?
I'm fairly handy with repairs like this, but I'm not sure if this further leak is something that's relatively simple to fix or whether I need to call a repair technician at this point to fix both? I'm concerned that if I simply replace the clutch that I will have another failure at some point in the future that could have been fixed by a simply O-ring replacement now. If this involves a lot of break-down work on the machine, I'm not sure I'm that comfortable with more disassembly.
Your input and assistance is greatly appreciated.
Thank you, Brian
Ads By Google
Related Models
Maytag FAV6800AWW WASHER-TOP LOADING
Maytag FAV9800AWQ WASHER-TOP LOADING
Maytag FAV9800AWW WASHER-TOP LOADING
Frigidaire FAX050P7A1 Frigidaire/air Conditioner
Frigidaire FAX050P7A2 Frigidaire/air Conditioner
Frigidaire FAX050P7A3 Frigidaire/air Conditioner
Frigidaire FAX050P7A4 Frigidaire/air Conditioner
Frigidaire FAX050P7A5 Frigidaire/air Conditioner
Frigidaire FAX050P7A6 Frigidaire/air Conditioner
Frigidaire FAX050P7A7 Frigidaire/air Conditioner
Frigidaire FAX050P7A8 Frigidaire/air Conditioner
Frigidaire FAX050P7AENG1 Frigidaire/air Conditioner
Frigidaire FAX050P7AENG2 Frigidaire/air Conditioner
Frigidaire FAX050P7AENG3 Frigidaire/air Conditioner
Frigidaire FAX050P7AENG4 Frigidaire/air Conditioner
Frigidaire FAX050P7AENG5 Frigidaire/air Conditioner
Frigidaire FAX050P7AENG6 Frigidaire/air Conditioner
Frigidaire FAX050S7A11 ROOM AIR CONDITIONER
Frigidaire FAX050S7A12 ROOM AIR CONDITIONER
Frigidaire FAX050S7A13 ROOM AIR CONDITIONER
Frigidaire FAX050S7A14 ROOM AIR CONDITIONER
Frigidaire FAX050S7A15 ROOM AIR CONDITIONER
Frigidaire FAX050S7A16 ROOM AIR CONDITIONER
Frigidaire FAX050S7A17 ROOM AIR CONDITIONER
Frigidaire FAX050S7AA ROOM AIR CONDITIONER
Frigidaire FAX050S7AB ROOM AIR CONDITIONER
Frigidaire FAX050S7AC ROOM AIR CONDITIONER
Frigidaire FAX050S7AD ROOM AIR CONDITIONER
Frigidaire FAX050S7AE ROOM AIR CONDITIONER
Frigidaire FAX050S7AF ROOM AIR CONDITIONER
Frigidaire FAX051P7A1 Frigidaire/air Conditioner
Frigidaire FAX051P7A2 Frigidaire/air Conditioner
Frigidaire FAX051P7A3 Frigidaire/air Conditioner
Frigidaire FAX051P7A4 Frigidaire/air Conditioner
Frigidaire FAX051P7A5 Frigidaire/air Conditioner
Frigidaire FAX051P7A6 Frigidaire/air Conditioner
Frigidaire FAX052P7A1 Frigidaire/air Conditioner
Frigidaire FAX052P7A11 ROOM A/C
Frigidaire FAX052P7A12 ROOM A/C
Frigidaire FAX052P7A13 ROOM A/C
Frigidaire FAX052P7A14 ROOM A/C
Frigidaire FAX052P7A15 ROOM A/C
Frigidaire FAX052P7A16 ROOM A/C
Frigidaire FAX052P7A2 Frigidaire/air Conditioner
Frigidaire FAX052P7A3 Frigidaire/air Conditioner
Frigidaire FAX052P7A4 Frigidaire/air Conditioner
Frigidaire FAX052P7A5 Frigidaire/air Conditioner
Frigidaire FAX052P7A6 Frigidaire/air Conditioner
Frigidaire FAX052P7AA ROOM A/C
Frigidaire FAX052P7AB ROOM A/C
Frigidaire FAX052P7AC ROOM A/C
Frigidaire FAX052P7AD ROOM A/C
Frigidaire FAX052P7AENG1 Frigidaire/air Conditioner
Frigidaire FAX052P7AENG2 Frigidaire/air Conditioner
Frigidaire FAX052P7AENG3 Frigidaire/air Conditioner
Frigidaire FAX052P7AENG4 Frigidaire/air Conditioner
Frigidaire FAX052P7AENG5 Frigidaire/air Conditioner
Frigidaire FAX052P7AENG6 Frigidaire/air Conditioner
Frigidaire FAX054P7A1 Frigidaire/air Conditioner
Frigidaire FAX054P7A11 ROOM A/C
Frigidaire FAX054P7A12 ROOM A/C
Frigidaire FAX054P7A13 ROOM A/C
Frigidaire FAX054P7A14 ROOM A/C
Frigidaire FAX054P7A15 ROOM A/C
Frigidaire FAX054P7A16 ROOM A/C
Frigidaire FAX054P7A2 Frigidaire/air Conditioner
Frigidaire FAX054P7A3 Frigidaire/air Conditioner
Frigidaire FAX054P7A4 Frigidaire/air Conditioner
Frigidaire FAX054P7A5 Frigidaire/air Conditioner
Frigidaire FAX054P7A6 Frigidaire/air Conditioner
Frigidaire FAX054P7AA ROOM A/C
Frigidaire FAX054P7AB ROOM A/C
Frigidaire FAX054P7AC ROOM A/C
Frigidaire FAX054P7AD ROOM A/C
Frigidaire FAX054P7AENG1 Frigidaire/air Conditioner
Frigidaire FAX054P7AENG2 Frigidaire/air Conditioner
Frigidaire FAX054P7AENG3 Frigidaire/air Conditioner
Frigidaire FAX054P7AENG4 Frigidaire/air Conditioner
Frigidaire FAX054P7AENG5 Frigidaire/air Conditioner
Frigidaire FAX054P7AENG6 Frigidaire/air Conditioner
Frigidaire FAZ085S1AA ROOM A/C
Frigidaire FAZ085S1AB ROOM A/C
Frigidaire FAZ085S7AA ROOM A/C
Frigidaire FAZ085S7AB ROOM A/C
Frigidaire FAZ08ES1AA ROOM A/C
Frigidaire FAZ08ES1AB ROOM A/C
Frigidaire FAZ08HR1A1 Frigidaire/air Conditioner
Frigidaire FAZ08HS1A11 ROOM AIR CONDITIONER
Frigidaire FAZ08HS1A12 ROOM AIR CONDITIONER
Frigidaire FAZ08HS1A13 ROOM AIR CONDITIONER
Frigidaire FAZ08HS1A14 ROOM AIR CONDITIONER
Frigidaire FAZ08HS1A15 ROOM AIR CONDITIONER
Frigidaire FAZ08HS1A16 ROOM AIR CONDITIONER
Frigidaire FAZ08HS1AA ROOM AIR CONDITIONER
Frigidaire FAZ08HS1AB ROOM AIR CONDITIONER
Frigidaire FAZ105S1AA ROOM A/C
Frigidaire FAZ105S1AB ROOM A/C
Frigidaire FAZ125S1AA ROOM A/C
Frigidaire FAZ125S1AB ROOM A/C
Frigidaire FAZ12ES2AA ROOM A/C
Frigidaire FAZ12ES2AB ROOM A/C
Frigidaire FAZ12HR2A2 Frigidaire/air Conditioner
Frigidaire FAZ12HS2A11 ROOM AIR CONDITIONER
Frigidaire FAZ12HS2A12 ROOM AIR CONDITIONER
Frigidaire FAZ12HS2A13 ROOM AIR CONDITIONER
Frigidaire FAZ12HS2AA ROOM AIR CONDITIONER
Frigidaire FAZ12HS2AB ROOM AIR CONDITIONER
Maytag FB10 DISPOSAL
Maytag FB11 DISPOSAL
Maytag FB20 DISPOSAL
Maytag FB21 DISPOSAL
Amana FB2221N WASHER-TOP LOADING
Amana FB7111N WASHER-TOP LOADING
Amana FB7221N WASHER-TOP LOADING
Whirlpool FB7700XR0 Floor care*
Whirlpool FB7700XS0 Floor care*
Whirlpool FB7700XS1 Floor care*
Whirlpool FB9900XR0 Floor care*
Whirlpool FB9900XS0 Floor care*
Frigidaire FBD2400KB0 DISHWASHER
  #2 (permalink)
Old 04-18-2011, 08:57 AM
Senior Member
dh1200s is on a distinguished road
Default
Brian,
When you removed the Clutch Pulley did your Series 16 machine use the upper One-Way bearing ring? See 1st pic. I’ll add some pics of what a normal clutch pulley should look like.
“”I'm concerned that if I simply replace the clutch that I will have another failure at some point in the future that could have been fixed by a simply O-ring replacement now””
Yes if you are going to keep the machine read on.
“”If this involves a lot of break-down work on the machine, I'm not sure I'm that comfortable with more disassembly.””
Yes read on to see if this is right for you.
AP4310552 http://www.appliancepartspros.com/part_details.aspx?part_id=4310552 Is the replacement Clutch Pulley I would buy. I would never recommend purchasing the $150+ Clutch pulley unless I had empirical data to support why the $150+ Clutch Pulley made this a better buy.
You have a Tub Seal leak that needs to be addressed and I would recommend a complete Outer Tub rebuild. See this post FAV6800A/FAV9800A Outer Tub bearing replacement and see what is involved to extend the service life of your FAV6800A.
If you decide rebuild the Outer Tub and have any questions I will help out……….Dick
File Type: jpg Series 10 Upper One-Way Roller Clutch ring before clean up..JPG (36.4 KB, 64 views)
  #3 (permalink)
Old 04-18-2011, 10:46 AM
Junior Member
Default
Dick:
Thank you for the quick follow-up and feedback. I believe the wife plans to keep the FAV6800AWW machine, so I am currently reviewing the Outer Tub Rebild thread you provided - thank you for this reference.
Regarding the question on the upper One-Way bearing ring, if this is the yellowish/greenish ring that sits on the top, then yes, my series 16 machine has this ring on top. This is where I initially saw the heavy rust that seems to be coming from the tub seal. After soaking with a little WD-40, wiping dry, then soaking in a little PB Blaster, it now seems to rotate fine within the rest of the assembly. The metal pin on the end of the spring is broken, thus the need for a replacement. I have all of the pieces noted in your series of pictures.
So, if you purchase the 4310552, do you no longer use the upper One-Way bearing ring, or do you simply attach this to the new clutch, so that it fits like the previous one did? Sorry if this is already obvious but I'm not sure I follow the previous discussions on this. I just want to make sure that I'm not purchasing more than I need to.
Thank you, Brian
  #4 (permalink)
Old 04-18-2011, 11:53 AM
Senior Member
Default
Hey Brian,
“”Regarding the question on the upper One-Way bearing ring, if this is the yellowish/greenish ring that sits on the top, then yes, my series 16 machine has this ring on top.””
This is real good news, you do not have the redesigned Outer Tub. The Outer Tub rebuild is a bit more straight forward.
""This is where I initially saw the heavy rust that seems to be coming from the tub seal. After soaking with a little WD-40, wiping dry, then soaking in a little PB Blaster, it now seems to rotate fine within the rest of the assembly.””
Make sure the One-Way bearings will allow what I call the Spinner Shaft coupler to rotate freely in one direction and Lock Up Rock Solid in the other. This a very straight forward Clutching assembly but if the One-Way Clutch bearing in the Clutch Pulley hub slips (white bearing plate) you will get agitator shaft rotation as the washer enters a spin cycle followed by the wash load being drug of balance and big time DC/UC unbalance errors.
The spring got stressed I feel by the by the Clutch Pulley mounted One-Way bearing seizing in the wash/agitate direction of Clutch Pulley rotation. I’ll attach a pic of a real bad one that you will see in the FAV6800A/FAV9800A Outer Tub bearing replacement post.
You might get back in service for a while depending how well the One-Way bearings clean up but the real fix is an Outer Tub rebuild and possible a clutch pulley replacement. I recommend Outer Tub bearings and the Spinner Support bearings be replaced with a complete tear down such as this.
“”The metal pin on the end of the spring is broken, thus the need for a replacement. I have all of the pieces noted in your series of pictures.””
Some owners have got back in service by reforming the Stainless Steel spring end. Heat it up and reformed the loop. Never had the issue so no real world experience on that as a possible fix which may be temp.
“”So, if you purchase the 4310552, do you no longer use the upper One-Way bearing ring, or do you simply attach this to the new clutch, so that it fits like the previous one did?””
You will get the Upper Bearing ring as part of the Clutch Pulley Assembly. Bolt it in and you are good to go. Just check the replacement Clutch Pulley assembly by insuring both bearings will Lock up in one direction and rotate freely in the other by rotating the Spinner Shaft Coupler. See my crude pic of the exploded parts labeled.
“”Sorry if this is already obvious but I'm not sure I follow the previous discussions on this. I just want to make sure that I'm not purchasing more than I need to.””
No need to be sorry I’m just an owner like you passing along my hands on experience to extend the service life of a $1K machine……….Dick
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool brake or clutch issue mtreu Washer Repair 18 10-08-2010 01:53 AM
Kenmore Elite gas leak - oven issue DennisL1 Oven Repair (including Ranges and Cooktops) 0 12-15-2009 10:32 PM
maytag fav6800aww washer clutch replacement pandsshearer Washer Repair 1 03-05-2009 05:50 PM
