| » Reset after board replacement |
Model Number: wbvh5200j3ww Brand: GE Age: Less than 1 year
Just replaced a main board on a GE washer and was wondering if there was a reset button or anything like that to reset.
Here are instructions for the control board on a model similar to yours. Since GE does not make it tech info available, we cannot say for certain that this will work on your model but it should.
Note: The replacement control board will always enter into test mode t01 on initial power-up. If replacing the control board, the washer will not function until the replacement control board has been programmed. Programming the Control Board 1. To program the replacement control board: Reconnect power to the washer. (The display will now show "---", which means no model has been selected.) 2. Rotate the cycle knob until the correct model number is displayed: Select 1 for model WHDVH626F Select 2 for model WCVH6260F Select 3 for model WBVH6240F 3. Press and hold the Start key for 3 seconds (or until a second beep is sounded). 4. Press the Power key to reset the control. Note: If an error is made in programming the control, enter test mode and select t01. Then repeat steps 2 thru 4.
__________________
| Display Modes | |
| How do I reset Kenmore Elite Washer Timer after replacement? | TimTroy | Washer Repair | 3 | 01-24-2011 03:43 PM |
| Control Board Reset??? | theob | Dishwasher Repair | 0 | 05-28-2010 12:20 PM |
| How to reset the control board | rrt | Dishwasher Repair | 0 | 10-11-2009 09:07 AM |
| How do I reset control board Bosch dishwasher | Aidandub8 | Dishwasher Repair | 1 | 07-30-2009 04:39 PM |
| Reset Control Board | mikeg1303 | Dishwasher Repair | 1 | 04-14-2009 07:36 PM |
