Discuss
I'm Lost-Please Help Me
 in
Washer Repair
Replaced CCU. made sure all connectors are in correct place and in tightly. Now F-13 code appears after machine is
Appliance Repair Forum > Appliance Repair Help > Washer Repair » I'm Lost-Please Help Me
  #1 (permalink)
Old 04-14-2011, 05:57 PM
Junior Member
rhta8702 is on a distinguished road
Default I'm Lost-Please Help Me
Model Number: GHW9100LW   Brand: Whirlpool   Age: 5 - 10 years
Replaced CCU. made sure all connectors are in correct place and in tightly. Now F-13 code appears after machine is on for 3 min. No water enters machine. Tested dispenser motor. Okay ( cam on top moves and there is 1400 ohms resistance). Checked water inlet valves. Tested okay. tested flowmeter. 0 ohms resistance and there is continuity. tested Dispenser switch. No reading on meter ( digital meter reads blinking "3"0.00). Now what do I do? Thankyou.
Ads By Google
Related Models
Whirlpool GHW9100LW0
Whirlpool GHW9100LW1
Whirlpool GHW9100LW2 Automatic Washer
Whirlpool GHW9150PW0 Automatic Washer
Whirlpool GHW9150PW1 Automatic Washer
Whirlpool GHW9150PW2 Automatic Washer
Whirlpool GHW9150PW3 Automatic Washer
Whirlpool GHW9150PW4 Automatic Washer
Whirlpool GHW9160PW0 Automatic Washer
Whirlpool GHW9160PW1 Automatic Washer
Whirlpool GHW9160PW2 Automatic Washer
Whirlpool GHW9160PW3 Automatic Washer
Whirlpool GHW9160PW4 Automatic Washer
Whirlpool GHW9200LQ0
Whirlpool GHW9200LW0
Whirlpool GHW9250ML0 Automatic Washer
Whirlpool GHW9250ML1 Automatic Washer
Whirlpool GHW9250ML2 Automatic Washer
Whirlpool GHW9250MQ0 Automatic Washer
Whirlpool GHW9250MQ1 Automatic Washer
Whirlpool GHW9250MQ2 Automatic Washer
Whirlpool GHW9250MT0 Automatic Washer
Whirlpool GHW9250MT1 Automatic Washer
Whirlpool GHW9250MT2 Automatic Washer
Whirlpool GHW9250MW0 Automatic Washer
Whirlpool GHW9250MW1 Automatic Washer
Whirlpool GHW9250MW2 Automatic Washer
Whirlpool GHW9300PW0 Automatic Washer
Whirlpool GHW9300PW1 Automatic Washer
Whirlpool GHW9300PW2 Automatic Washer
Whirlpool GHW9300PW3 Automatic Washer
Whirlpool GHW9300PW4 Automatic Washer
Whirlpool GHW9400PL0 Automatic Washer
Whirlpool GHW9400PL1 Automatic Washer
Whirlpool GHW9400PL2 Automatic Washer
Whirlpool GHW9400PL3 Automatic Washer
Whirlpool GHW9400PL4 Automatic Washer
Whirlpool GHW9400PT0 Automatic Washer
Whirlpool GHW9400PT1 Automatic Washer
Whirlpool GHW9400PT2 Automatic Washer
Whirlpool GHW9400PT3 Automatic Washer
Whirlpool GHW9400PT4 Automatic Washer
Whirlpool GHW9400PW0 Automatic Washer
Whirlpool GHW9400PW1 Automatic Washer
Whirlpool GHW9400PW2 Automatic Washer
Whirlpool GHW9400PW3 Automatic Washer
Whirlpool GHW9400PW4 Automatic Washer
Whirlpool GHW9400SU0 Automatic Washer
Whirlpool GHW9460PL0 Automatic Washer
Whirlpool GHW9460PL1 Automatic Washer
Whirlpool GHW9460PL2 Automatic Washer
Whirlpool GHW9460PL3 Automatic Washer
Whirlpool GHW9460PL4 Automatic Washer
Whirlpool GHW9460PW0 Automatic Washer
Whirlpool GHW9460PW1 Automatic Washer
Whirlpool GHW9460PW2 Automatic Washer
Whirlpool GHW9460PW3 Automatic Washer
Whirlpool GHW9460PW4 Automatic Washer
Whirlpool GHWT160JXX0
Whirlpool GI1500PHB0
Whirlpool GI1500PHB3
Whirlpool GI1500PHB4 Ice Cube Maker
Whirlpool GI1500PHB5 Ice Cube Maker
Whirlpool GI1500PHB6 Ice Cube Maker
Whirlpool GI1500PHB7 Ice Cube Maker
Whirlpool GI1500PHB8 Ice Cube Maker
Whirlpool GI1500PHW0
Whirlpool GI1500PHW3
Whirlpool GI1500PHW4 Ice Cube Maker
Whirlpool GI1500PHW5 Ice Cube Maker
Whirlpool GI1500PHW6 Ice Cube Maker
Whirlpool GI1500PHW7 Ice Cube Maker
Whirlpool GI1500PHW8 Ice Cube Maker
Whirlpool GI1500XHB0
Whirlpool GI1500XHB1
Whirlpool GI1500XHB2
Whirlpool GI1500XHB3
Whirlpool GI1500XHB4 Ice Cube Maker
Whirlpool GI1500XHB5 Ice Cube Maker
Whirlpool GI1500XHB6 Ice Cube Maker
Whirlpool GI1500XHB7 Ice Cube Maker
Whirlpool GI1500XHB8 Ice Cube Maker
Whirlpool GI1500XHB9 Ice Cube Maker
Whirlpool GI1500XHN0
Whirlpool GI1500XHN1
Whirlpool GI1500XHN2
Whirlpool GI1500XHN3
Whirlpool GI1500XHN4 Ice Cube Maker
Whirlpool GI1500XHS0
Whirlpool GI1500XHS1
Whirlpool GI1500XHS2
Whirlpool GI1500XHS3
Whirlpool GI1500XHS4 Ice Cube Maker
Whirlpool GI1500XHS5 Ice Cube Maker
Whirlpool GI1500XHS6 Ice Cube Maker
Whirlpool GI1500XHS7 Ice Cube Maker
Whirlpool GI1500XHS8 Ice Cube Maker
Whirlpool GI1500XHS9 Ice Cube Maker
Whirlpool GI1500XHT1
Whirlpool GI1500XHT2
Whirlpool GI1500XHT3
Whirlpool GI1500XHT4 Ice Cube Maker
Whirlpool GI1500XHT5 Ice Cube Maker
Whirlpool GI1500XHT6 Ice Cube Maker
Whirlpool GI1500XHT7 Ice Cube Maker
Whirlpool GI1500XHT8 Ice Cube Maker
Whirlpool GI1500XHT9 Ice Cube Maker
Whirlpool GI1500XHW0
Whirlpool GI1500XHW1
Whirlpool GI1500XHW2
Whirlpool GI1500XHW3
Whirlpool GI1500XHW4 Ice Cube Maker
Whirlpool GI1500XHW5 Ice Cube Maker
Whirlpool GI1500XHW6 Ice Cube Maker
Whirlpool GI1500XHW7 Ice Cube Maker
Whirlpool GI1500XHW8 Ice Cube Maker
Whirlpool GI1500XHW9 Ice Cube Maker
Whirlpool GI15NDXTB0 Ice Cube Maker
Whirlpool GI15NDXTB1 Ice Cube Maker
Whirlpool GI15NDXTQ0 Ice Cube Maker
  #2 (permalink)
Old 04-16-2011, 05:25 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
A couple of questions
1. How did you test the water valve assembly? Obviously it is not getting power, although we don't know why.
2. What was the original problem that caused you to replace the CCU?
I would check the wiring harness from the CCU to the various components, including the door lock assembly for continuity. Also check the door lock assembly. Yes, we know that has nothing to do with the error code, but that is life with these microprocessor controls.
__________________
  #3 (permalink)
Old 04-17-2011, 07:55 AM
Junior Member
Default
Water inlet valves tested as per service manual.Tried new Pressure switch, no change. Tested Dispenser switch & motor (as per manual-Tested okay).Drain pump motor-0 ohms on scale,15 ohms on continunity scale.Door unlock/lock solenoids-#3-2, 60 ohms, #3-1,.123Kohms. Door lock main switchs 5-4 & 2-1-0 ohms. Door switch open & closed-0 ohms. The original problem is would not complete cycles. Code F-12 (no drain) will show. Sometimes water in drum. Sometimes door would unlock, other times would not unlock ( both with and without water left in drum). After pushing pause twice, system would not reset. Sometimes rinse/drain would work & other times not. Occaisionly machine would work fine. Pump was checked for obstructions, was spotlessly clean, so was pressure tube. Please check prior entry's for more info.
  #4 (permalink)
Old 04-17-2011, 04:48 PM
Senior Expert
APP Volunteer
Default
The test only shows that the valve switch has continuity.
Use a meter to see if voltage is coming to the water inlet valve assembly when it supposed to be filling. If so, replace the water valve assembly. If it is not, and you are sure you have voltage going to the CCU then you may have gotten a bad CCU replacement board.
I am also suspicous of the door lock assembly, because I am always suspicous of the door lock assembly on these models.
That's all I got right now.
__________________
  #5 (permalink)
Old 04-27-2011, 08:36 PM
Junior Member
Default I'm lost update.
The last time I wrote, it was suggested that I replace door latch and check for voltage at computer and voltage at water valves. Replaced door latch. Door now locks. Water valves had NO voltage. Replaced replacement computer with original unit. Upon running machine, code for "no water " showed after 3 minutes of run time. I could hear water entering machine. Placed dial on "Spin/Drain". Saw plenty of water draining from drain hose. Decided to try new "Rebuilt" computer. Same result as 1st replacement computer. After much discussion with sister, it was decided to return computer and door switch and scrap washer. This machine is 8 1/2 years old. Too much agravation trying to fix. Thankyou for your help.
P.S. Talked with appliance repairman friend in Florida last week. He told me he scrapped 9 machines 2 weeks ago. Their ages were from 2 years to 7 years of age. Cost to fix was more than machine was worth. 3 machines had computer problems ( some were 2 years old).
  #6 (permalink)
Old 04-28-2011, 04:50 AM
Senior Expert
APP Volunteer
Default
Well I am sorry we were not able to get you up and running, but you have experienced the problem with these over engineered, overly complex models. The electronics are just so complex and unreliable that often your situation becomes the norm.
Good luck with your new washer. Thanks for the update.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Lost board jchong Refrigerator & Freezer Repair 0 03-21-2011 02:22 PM
I'm lost!!! pondmaster Oven Repair (including Ranges and Cooktops) 5 12-19-2009 02:37 AM
Lost information gwh1964 Oven Repair (including Ranges and Cooktops) 0 11-04-2009 04:06 PM
