I figured out how to open the top of the washer and felt the leak coming out from under the tub (after being filled with water) but I can't pinpoint if its the hose, seal, etc because I can't see it from the top. So my question is...how do I get into the cabinet other than through the top so I can see under the tub?
Groups ready for retrieval: Senior Expert
On that product, you need to get a sturdy putty knife and slide it under the top, about 2 inches from each end, and release the clips. Then push the top back and rest it against the back wall. Now we need to get the front off. Look inside the front up top on the left side, and you will see a screw. Take it out, and the one on the other side, and then remove the front. Tom
