Discuss
Whirlpool washer won't spin on the gentle knit cycle
 in
Washer Repair
This is a top load washer. All cycles work except for the Gentle Knit cycle. In the Gentle Knit cycle,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool washer won't spin on the gentle knit cycle
  #1 (permalink)
Old 04-14-2011, 09:48 AM
Junior Member
Bowdaddy is on a distinguished road
Default Whirlpool washer won't spin on the gentle knit cycle
Model Number: LA6800XTW0   Brand: Whirlpool   Age: More than 10 years
This is a top load washer. All cycles work except for the Gentle Knit cycle. In the Gentle Knit cycle, it will fill with water, sometimes it only agitates briefly, sometimes it will spin and sometimes it will not, and sometimes it will drain and sometime it will not. I have replaced the lid switch and bypassed the lid switch. Looked at the clutch and it seems fine. I am thinking the problem is either the dial timer or the motor since it is a 2 speed motor. How would I check these two items? Also if it is not these 2 items, what do you think it is?
Related Models
Whirlpool LA6800XTW0 AUTOMATIC WASHER
Whirlpool LA6800XTW1
Whirlpool LA6888XTF0
Whirlpool LA6888XTG0
Whirlpool LA6888XTG1
Whirlpool LA6888XTM0
Whirlpool LA6888XTN0
Whirlpool LA6888XTN1
Whirlpool LA6888XTW0
Whirlpool LA6888XTW1
Whirlpool LA6900XKW2
Maytag LA6910 WASHER-TOP LOADING
Whirlpool LA7000XKW1
Whirlpool LA7000XKW2
Whirlpool LA7000XMW0
Whirlpool LA7000XPW0
Whirlpool LA7000XPW1
Whirlpool LA7000XSW0
Whirlpool LA7000XSW1
Whirlpool LA7000XTF0
Whirlpool LA7000XTF1
Whirlpool LA7000XTG0
Whirlpool LA7000XTG1
Whirlpool LA7000XTM0
Whirlpool LA7000XTM1
Whirlpool LA7000XTN0
Whirlpool LA7000XTN1
Whirlpool LA7000XTW0
Whirlpool LA7000XTW1
Whirlpool LA7001XSW0
Whirlpool LA7001XTF1
Whirlpool LA7001XTG1
Whirlpool LA7001XTM1
Whirlpool LA7001XTN1
Whirlpool LA7001XTW0
Whirlpool LA7001XTW1
Whirlpool LA7005XKW1
Whirlpool LA7005XMW0
Whirlpool LA7005XPW0
Whirlpool LA7005XPW1
Frigidaire LA700AXD1 Wwh(v4) / 27 " Washer
Frigidaire LA700AXD2 Wwh(v4) / 27 " Washer
Frigidaire LA700AXD3 Wwh(v3) / 27 " Washer
Frigidaire LA700AXW1 Wwh(v3) / 27 " Washer
Frigidaire LA700AXW2 Wwh(v3) / 27 " Washer
Frigidaire LA700AXW3 Wwh(v4) / 27 " Washer
Frigidaire LA700MXD1 Wwh(v6) / 27 " Washer
Frigidaire LA700MXW1 Wwh(v5) / 27 " Washer
Whirlpool LA7088XTF0
Whirlpool LA7088XTF1
Whirlpool LA7088XTG0
Whirlpool LA7088XTG1
Whirlpool LA7088XTM0
Whirlpool LA7088XTM1
Whirlpool LA7088XTN0
Whirlpool LA7088XTN1
Whirlpool LA7088XTW0
Whirlpool LA7088XTW1
Maytag LA712 WASHER-TOP LOADING
Maytag LA7300 WASHER-TOP LOADING
Maytag LA7400 WASHER-TOP LOADING
Whirlpool LA7400XMW0
Whirlpool LA7400XMW1
Whirlpool LA7400XMW2
Whirlpool LA7400XMW3
Whirlpool LA7450XMW0
Whirlpool LA7450XMW1
Whirlpool LA7460XMW0
Maytag LA7500 WASHER-TOP LOADING
Maytag LA7500S WASHER-TOP LOADING
Maytag LA7500W WASHER-TOP LOADING
Whirlpool LA7500XKW0
Frigidaire LA750EXD3 Wwh(v6) / Washer
Frigidaire LA750EXF3 Wwh(v7) / Washer
Frigidaire LA750EXH3 Wwh(v8) / Washer
Frigidaire LA750EXV3 Wwh(v9) / Washer
Frigidaire LA750EXW3 Wwh(v10) / Washer
Frigidaire LA750MXD1 Wwh(v2) / 27 " Washer
Frigidaire LA750MXW1 Wwh(v1) / 27 " Washer
Whirlpool LA7680XKW1
Whirlpool LA7680XKW2
Whirlpool LA7680XMW0 Washers*
Whirlpool LA7680XPW0
Whirlpool LA7680XPW1
Whirlpool LA7680XPW2
Whirlpool LA7680XSW0
Whirlpool LA7680XSW1
Whirlpool LA7680XTF0
Whirlpool LA7680XTF1
Whirlpool LA7680XTG0
Whirlpool LA7680XTG1
Whirlpool LA7680XTM0
Whirlpool LA7680XTM1
Whirlpool LA7680XTN0
Whirlpool LA7680XTN1
Whirlpool LA7680XTW0
Whirlpool LA7680XTW1
Whirlpool LA7681XSW0
Whirlpool LA7681XSW1
Whirlpool LA7685XKW1
Whirlpool LA7685XPW0
Whirlpool LA7685XPW1
Whirlpool LA7685XPW2
Whirlpool LA7700XPW0
Whirlpool LA7700XPW1
Whirlpool LA7700XPW3
Whirlpool LA7700XPW4
Whirlpool LA7700XPW5
Whirlpool LA7700XSW0
Whirlpool LA7700XWN0
Whirlpool LA7700XWW0
Whirlpool LA7780XSW0
Whirlpool LA7780XSW1 Washers*
Whirlpool LA7780XSW2
Maytag LA7800 WASHER-TOP LOADING
Whirlpool LA7800XKW2
Whirlpool LA7800XMW0
Whirlpool LA7800XPW0
Whirlpool LA7800XPW1 Washers*
Whirlpool LA7800XSF2 AUTOMATIC WASHER
  #2 (permalink)
Old 04-15-2011, 05:32 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Your three choices are the motor, motor switch and the timer. Given the it works in the gentle cycle some of the time I am leaning towards the timer. You can disconnect the wiring and clean the contacts and if that does not fix things try a new timer.
If you buy from this site and the part does not fix the problem you can return it, see the returns policy for details and conditions.
__________________
  #3 (permalink)
Old 04-19-2011, 09:23 AM
Junior Member
Default
I think I got it fixed. I replaced the timer and so far so good. Thanks for all of your replies.
  #4 (permalink)
Old 04-19-2011, 01:44 PM
Senior Expert
APP Volunteer
Default
Great, good luck with it and thanks for the update.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool won't spin on gentle knit cycle Bowdaddy Washer Repair 2 04-17-2011 09:38 AM
Whirlpool washer squealing in regular cycle not gentle cycle cttntal209 Washer Repair 0 12-13-2010 09:11 AM
Will not Spin/Drain in Knit/Gentle Cycle RobertH Washer Repair 0 03-02-2009 07:37 AM
Maytag wash won't spin on regular cycle but will on gentle cycle BlazingSun Washer Repair 0 01-07-2009 08:41 PM
Gentle cycle/slow spin speed problem WFH Washer Repair 1 01-19-2008 08:17 PM
