Discuss
Maytag washer begins spinning, stops and shuts down
 in
Washer Repair
Maytag washer stops spinning after rinse water has mostly emptied and then shuts down cold. I ran it with no
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag washer begins spinning, stops and shuts down
  #1 (permalink)
Old 04-13-2011, 07:40 PM
Junior Member
herbyreed is on a distinguished road
Default Maytag washer begins spinning, stops and shuts down
Brand: -brand-   Age: More than 10 years
Maytag washer stops spinning after rinse water has mostly emptied and then shuts down cold. I ran it with no clothes in it - turned the timer to the spin cycle. It filled up with water, spin started until most water emptied, then shut down cold. Will not restart unless I set it to the beginning of the spin cycle again, then it will again fill with water and repeat the pattern. Belts a little loose but even if belts removed the motor will not run if dial is turned past the water fill part of the spin cycle. I am guessing the timer is bad. Lid switch is ok - checked with ohm meter. I don't believe this model has any solenoids.
  #2 (permalink)
Old 04-14-2011, 07:38 AM
Junior Member
MarkSchultz is on a distinguished road
Unhappy washing machine stops mid-cycle
Having the same problem with Whirlpool LXR9445JQO. I replaced the timer, but stops in the same place (6 min) regarless of cycle selection (quick,delicate,heavy,etc). Troubleshooting says replace the coupler behind the motor, but the motor isn't running at that point. Is this an electrical problem?
  #3 (permalink)
Old 04-14-2011, 06:35 PM
Junior Member
Default
Ok I figured it out. The bulb on the tube which comes up to the vacuum fill switch was filled up with gunk. I cleaned it out and voila! It worked. For a while. I had taken the tub apart and apparently didn't get it back together right because it is binding now. The belt started squealing and smoking. But at least I know what the problem is/was. I will fix it tomorrow. I know one other time I took the tub apart and had trouble getting it back together. Next time I will just clean out the bulb and forget about taking the tub apart.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Stops Spinning alanbradycollin Washer Repair 3 01-28-2012 07:43 PM
Washer stops in middle of cycle shuts off hellmanjeffrey@yahoo.com Refrigerator & Freezer Repair 4 01-10-2010 09:19 AM
GE washer stops spinning randy neel Washer Repair 1 08-27-2009 01:51 PM
Washer Stops spinning billygrav Washer Repair 0 04-19-2008 04:04 PM
Maytag tub bangs when it stops spinning hoseman Washer Repair 2 03-16-2008 07:19 AM
