Discuss
lid switch part
 in
Washer Repair
I have a [FONT='Arial','sans-serif'] Kenmore washer model 110.28812790. My lid switch is physically broken where the lid post would activate
Appliance Repair Forum > Appliance Repair Help > Washer Repair » lid switch part
  #1 (permalink)
Old 04-13-2011, 10:24 AM
Junior Member
bobmole is on a distinguished road
Default lid switch part
Model Number: 110.28812790   Brand: Kenmore   Age: 1 - 5 years
I have a [FONT='Arial','sans-serif']Kenmore washer model 110.28812790. My lid switch is physically broken where the lid post would activate it. I can use a small screw driver and activate the switch. The actuator part pics do not match what I can see on my machine. And I cannot tell if the lid switch assembly will fit for my machine. Help please.......</SPAN>[/font]
Ads By Google
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 04-14-2011, 06:36 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Call in your order to APP and they will get you the right part. If you need a new actuator, order that also.
__________________
  #3 (permalink)
Old 04-15-2011, 05:30 AM
Junior Member
Default
I think that I only need one part. I can make the spin cycle work by pressing on the remains of a recessed lever on the machine lid switch so the lid switch is still functional. So I might only need the actuator. But I cannot see how it would attach to the existing switch. How do I determine what is actually needed????
  #4 (permalink)
Old 04-15-2011, 05:34 AM
Senior Expert
APP Volunteer
Default
Ok, I am maybe a little confused on what you called the actuator. I refer to it as the plastic piece that is attached to the lid and engages the lid switch.
If you mean something on the lid switch itself, the answer that the lid switch is sold as a single unit and is not separately repairable.
__________________
  #5 (permalink)
Old 04-15-2011, 05:44 AM
Junior Member
Default
Ok. I have the plastic piece to activate the switch. But, I found this on the site. I have tried to attach a jpg of the actuator that I am talking about. However, I am not sure it attached.
  #6 (permalink)
Old 04-15-2011, 05:58 AM
Senior Expert
APP Volunteer
Default
Ok, here is the lid switch that is listed for your machine by both Sears and APP (APP is a lot less expensive)
WHIRLPOOL 3949238 Lid switch assembly, AP3100001 | AppliancePartsPros.com
The picture you posted is the actuator, which is the plastic piece that engages the lid switch. From what you have said, it sounds like your actuator is ok, (they usually are) and that it is the lid switch itself that needs replacing. If you need to replace the actuator, it has plastic tabs which can be squeeze with needle nose pliers to remove the old one from the lid and the new one can then be just inserted and it will snap in.
__________________
  #7 (permalink)
Old 04-15-2011, 06:01 AM
Junior Member
Default
Thanks for your help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
G E burner switch/part#conversion LGRAHAM Oven Repair (including Ranges and Cooktops) 1 12-29-2012 08:53 AM
Jenn-Air micro switch part raz747 Oven Repair (including Ranges and Cooktops) 2 03-09-2010 02:19 PM
new revisedpressure switch part does not fit in machine lotsofdirtyclothes Washer Repair 4 07-02-2009 11:31 AM
Maytag lid switch part number klp Washer Repair 3 11-14-2008 08:45 AM
GE selector switch part search user99 Oven Repair (including Ranges and Cooktops) 4 11-03-2008 10:00 AM
