Discuss
Frigidaire Front Load New Door Lock
 in
Washer Repair
I recently replaced the door lock mechanism on the fwt445ges2 washer. I installed the new part that was re-engineered
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidaire Front Load New Door Lock
  #1 (permalink)
Old 10-30-2007, 11:53 AM
kcchadmac kcchadmac is offline
Junior Member
kcchadmac is on a distinguished road
Default Frigidaire Front Load New Door Lock
Model Number: fwt445ges2   Brand: Frigidaire   Age: 5 - 10 years
I recently replaced the door lock mechanism on the fwt445ges2 washer. I installed the new part that was re-engineered for this model including the new counter-weight. After following the cryptic instructions, I ended up with an extra wiring harness. It is a two blade male harness with a pink-red wire and a white wire leading into it. For the life of me I cannot figure out where it goes. Also, the washer will not go into fast spin mode. I'm guessing it has something to do with the extra harness??? Thanks in advance for your help.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-16-2007, 07:38 PM
heyingh heyingh is offline
Junior Member
heyingh is on a distinguished road
Default
I also have problem with door lock. I find the part from internet and find there is a big part like arc. Shall I have to remove this part? How can i remove it? Shall I have to remove the front panel or ring-tub?
thanks,
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore front load washer drum off balance and bangs in one location kemily Washer Repair 2 12-18-2007 04:02 PM
spin cycle on frigidaire front load Mikki Washer Repair 2 10-08-2007 05:15 PM
GE Front Load Washer Won't Drain scottbreen Washer Repair 2 10-06-2007 09:46 PM
front load washer starts and stops immediately sunshine Washer Repair 0 10-01-2007 07:16 AM
how do I: remove rear drum bearing frigid front load? treefrog Washer Repair 0 08-19-2007 02:12 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
