Discuss
GEb washer timer
 in
Washer Repair
Hi, I have a GE washer that will not automatically move from cycle to cycle. I believe it is the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GEb washer timer
  #1 (permalink)
Old 04-12-2011, 07:54 AM
Junior Member
DavidD61 is on a distinguished road
Question GEb washer timer
Model Number: WLSR300061WW   Brand: GE   Age: 1 - 5 years
I have a GE washer that will not automatically move from cycle to cycle. I believe it is the timer as as cycles work fine if you manually move the knob from wash to rinse to spin. Also the timer itself it very loud like a bad egg timer
If this is the case is replacing the timer a do it your self project?
Ads By Google
Related Models
General Electric WLSR3000G0WW Washer
Frigidaire WLW0 Frg(v1) / 27 " Washer
Frigidaire WLW1 Frg(v1) / 27 " Washer
General Electric WLW1500BAL Washer
General Electric WLW1500BBL Washer
General Electric WLW1500BCL Washer
General Electric WLW1500BNL Washer
General Electric WLW1500RBL Washer
General Electric WLW2330BAL Washer
General Electric WLW2500BAL Washer
General Electric WLW2500BBL Washer
General Electric WLW2500BCL Washer
General Electric WLW2500BNL Washer
General Electric WLW2500RBL Washer
Frigidaire WLW3 Frg(v1) / 27 " Washer
General Electric WLW3000BAL Washer
General Electric WLW3000BBL Washer
General Electric WLW3000BCL Washer
General Electric WLW3000BNL Washer
General Electric WLW3000RBL Washer
General Electric WLW3000SALWH Washer
General Electric WLW3200SALWH Washer
General Electric WLW3200SBLWH Washer
General Electric WLW3300BBL Washer
General Electric WLW3300BCL Washer
General Electric WLW3300BNL Washer
General Electric WLW3300RBL Washer
General Electric WLW3310BBL Washer
General Electric WLW3310BCL Washer
General Electric WLW3310BNL Washer
General Electric WLW3310RBL Washer
General Electric WLW3400SALAD Washer
General Electric WLW3400SALWH Washer
General Electric WLW3400SBLAD Washer
General Electric WLW3400SBLWH Washer
General Electric WLW3440SALAD Washer
General Electric WLW3440SALWH Washer
General Electric WLW3440SBLAD Washer
General Electric WLW3440SBLWH Washer
General Electric WLW3500BAL Washer
General Electric WLW3500BBL Washer
General Electric WLW3500BCL Washer
General Electric WLW3500BNL Washer
General Electric WLW3500RBL Washer
General Electric WLW3505BAL Washer
General Electric WLW3505BBL Washer
General Electric WLW3600BBL Washer
General Electric WLW3600BCL Washer
General Electric WLW3600BNL Washer
General Electric WLW3600SALAD Washer
General Electric WLW3600SALWH Washer
General Electric WLW3600SBLAD Washer
General Electric WLW3600SBLWH Washer
General Electric WLW3610SALWW Washer
General Electric WLW3610SBLWW Washer
General Electric WLW3700BAL Washer
General Electric WLW3700BBL Washer
General Electric WLW3700BCL Washer
General Electric WLW3700BNL Washer
General Electric WLW3700BPL Washer
General Electric WLW3700RBL
General Electric WLW3700RBLWW Washer
General Electric WLW3750BAL Washer
General Electric WLW3750BBL Washer
General Electric WLW3750BNL Washer
General Electric WLW3750RBL Washer
General Electric WLW3760RBLWW Washer
General Electric WLW3800SALAD Washer
General Electric WLW3800SALWH Washer
General Electric WLW3800SBLAD Washer
General Electric WLW3800SBLWH Washer
General Electric WLW3810SALWW Washer
General Electric WLW3810SBLWW Washer
General Electric WLW4700BAL Washer
General Electric WLW4700BBL Washer
General Electric WLW4700BCL Washer
General Electric WLW4700BNL Washer
General Electric WLW5700BAL Washer
General Electric WLW5700BBL Washer
General Electric WLW5700BCL Washer
General Electric WLW5700BNL Washer
General Electric WLW5700RBL Washer
General Electric WLW5900MAL Washer
General Electric WLW5900MNL Washer
Frigidaire WLXG42RED0 Wwh(v1) / Laundry Center
White Westinghouse WLXG42RED1 Laundry Center - W.westinghouse
Frigidaire WLXG42RED3
Frigidaire WLXG42REW0 Wwh(v2) / Laundry Center
White Westinghouse WLXG42REW1 Laundry Center - W.westinghouse
White Westinghouse WLXG42REW2 Laundry Center - West/famsa
White Westinghouse WLXG42REW3 White Westinghouse/laundry Center
White Westinghouse WLXG42REW4 White Westinghouse/laundry Center
White Westinghouse WLXG42REW5 White Westinghouse/laundry Center
General Electric WLXR1020T2WB Washer
General Electric WLXR1020T3WB Washer
General Electric WLXR1020T4WB Washer
General Electric WLXR1020T5WB Washer
General Electric WLXR1020T8WB Washer
General Electric WLXR1020TAWB Washer
Jenn-Air WM227B Walloven - S/c Mwave Ele
Jenn-Air WM227W Walloven - S/c Mwave Ele
Jenn-Air WM236B Walloven - S/c Mwave Ele
Jenn-Air WM236W Walloven - S/c Mwave Ele
Jenn-Air WM27160B Walloven - S/c Mwave Ele
Jenn-Air WM27160W Walloven - S/c Mwave Ele
Jenn-Air WM2720B Walloven - S/c Mwave Ele
Jenn-Air WM2720W Walloven - S/c Mwave Ele
Jenn-Air WM27260B Walloven - S/c Mwave Ele
Jenn-Air WM27260W Walloven - S/c Mwave Ele
Jenn-Air WM27460B Walloven - S/c Mwave Ele
Jenn-Air WM27460W Walloven - S/c Mwave Ele
Jenn-Air WM2750B Walloven - S/c Mwave Ele
Jenn-Air WM2750W Walloven - S/c Mwave Ele
Jenn-Air WM277B Walloven - S/c Mwave Ele
Jenn-Air WM277W Walloven - S/c Mwave Ele
Jenn-Air WM2780 Walloven - S/c Mwave Ele
Jenn-Air WM2780B Walloven - S/c Mwave Ele
Jenn-Air WM2780W Walloven - S/c Mwave Ele
Jenn-Air WM30460B Walloven - S/c Mwave Ele
Jenn-Air WM30460W Walloven - S/c Mwave Ele
  #2 (permalink)
Old 04-13-2011, 07:17 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I think it is the timer, and yes, it is a pretty easy job that you can do yourself.
First take off the timer knob. It is held on by a plastic clip which you can remove with needle nose pliers after you pull the knob out. The take out the screws on top of the console to get to the inside of the console, remove the old timer and replace it with the new one. Just make sure the wires go back as they were originally.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag washer, timer good till rinse-no spin,drain orstop/timer keeps clicking freely partsparts Washer Repair 3 08-23-2010 01:50 AM
washer pump / washer timer jwm423 Washer Repair 1 07-26-2010 02:31 PM
washer timer mikeg201 Washer Repair 0 06-17-2010 08:53 AM
help how do you speciffically replace washer timer on Maytag washer stupid1 Washer Repair 5 07-04-2009 05:21 PM
bad timer on washer jeremy75 Washer Repair 1 01-17-2009 07:30 PM
