This frontload washer will wash but it cuts off in the middle of the cycle. when it does you have to then press the rinse button but then it cuts off before time and then you have to hit drain and spin for it to finish what could be causing this machine to be doing this.
We also have another on that is a Frigidaire Model#-GLTF2940EE0 it works real good but in the middle of the cycle it just completely turns off. What causes this to happen.
Look inside the lower service panel on these models and you should find tech notes that will tell you how to troubleshoot the symptons.
Focus on the speed or motor control board and the door lock assembly, the weak points on these models.
