jking
#1 Posted : Monday, April 11, 2011 8:53:35 AM(UTC)
jking
Washer Will Agitate But Will Slow Down And Cut Off Same With Spin Cycle .i Also Here A Clicking Noise When It Slows Down.have Changed The Mount On Motor Please Help.
sidfink43
#2 Posted : Wednesday, April 13, 2011 7:55:34 AM(UTC)
sidfink43
Use the Sticky at the top of the page on direct drive brakes and this video
YouTube - Washing Machine Clutch Band and Lining Repair Kit Replacement (part #285790)
to check out and change the clutch and check the brakes.
#3 Posted : Wednesday, April 13, 2011 8:27:09 AM(UTC)
From the description, might be a burnt wire someplace, a bad timer,or a bad motor, this assumes the washer acts up in agitate also.
I would pull the cover off the timer and check for bad contacts.
MarkSchultz
#4 Posted : Thursday, April 14, 2011 7:00:38 AM(UTC)
MarkSchultz
I checked terminal connections throughout my Whirlpool LXR9445JQO and found no problems. I put a new $100 timer in and it still fails mid-cycle. Please advise.
#5 Posted : Thursday, April 14, 2011 2:09:15 PM(UTC)
Do the tranny coupler test to check the brakes in my sticky "Replacing direct drive washer brake shoes".
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Stem question about Naytag 2-belt washing machine (Washer Repair)
by Hotrodjohn71 1/2/2024 7:50:48 AM(UTC)
Maytag Oasis HE Washing Machine (Washer Repair)
by Guest 12/8/2023 12:55:45 PM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
whirlpool model wtw7300dw2 washing machine (Washer Repair)
by Guest 11/8/2023 9:27:17 AM(UTC)
MVWB965HC0 Washing Machine - Need Service Manual or Video to Replace Touchpad and Control Assembl (Washer Repair)
by Guest 10/30/2023 8:11:10 PM(UTC)
Best vintage, American made washing machines (Washer Repair)
by Guest 10/30/2023 5:27:34 AM(UTC)
Washing machine not washing clothes properly (Washer Repair)
by Guest 9/20/2023 11:56:24 AM(UTC)
Washing Machine fill with water but will not spin, rinse or agitate. (Washer Repair)
by jmaiso 9/1/2023 7:04:07 AM(UTC)
Washing machine do not complete the cycle (Washer Repair)
by Guest 8/16/2023 10:02:15 AM(UTC)
Mayag washing machine - possibly locked motor? (Washer Repair)
by crp0499 5/19/2023 3:02:19 AM(UTC)
Recommended replacement for WP22001311 Maytag Washing Machine Unbalance lever (Washer Repair)
by Guest 4/29/2023 12:17:37 PM(UTC)
Whirlpool washing machine drive hub (Washer Repair)
by Guest 4/23/2023 7:29:26 AM(UTC)
Extension hose for GE washing machine GFW850SPNRS (Washer Repair)
by Guest 3/17/2023 9:53:53 PM(UTC)
Maytag washing machine MHW6630HW - looking for electrical diagram (Washer Repair)
by jessman1128 2/8/2023 12:45:11 PM(UTC)
