Discuss
Stator continuity check?
 in
Washer Repair
Drum won't spin. Unit is telling me that "Motor is not rotating properly". Is there a way to do a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Stator continuity check?
  #1 (permalink)
Old 04-10-2011, 10:12 AM
Junior Member
Chequamegon is on a distinguished road
Default Stator continuity check?
Model Number: WPGT9350C0WW   Brand: GE   Age: 5 - 10 years
Drum won't spin. Unit is telling me that "Motor is not rotating properly". Is there a way to do a continuity check on the Stator to see if thats the issue or if it could just be a relay not sending AC to the stator?
Related Models
General Electric WPGT9350C0WW Washer
General Electric WPGT9360C0PL Washer
General Electric WPGT9360C0WW Washer
General Electric WPGT9360E0PL Washer
General Electric WPGT9360E0WW Washer
General Electric WPRB8050D0CC Washer
General Electric WPRB8050D0WW Washer
General Electric WPRB8050D1CC Washer
General Electric WPRB8050D1WW Washer
General Electric WPRB8350H0WT WASHER
General Electric WPRB9110D0CC Washer
General Electric WPRB9110D0WW Washer
General Electric WPRB9110D1CC Washer
General Electric WPRB9110D1WW Washer
General Electric WPRB9220C0CC Washer
General Electric WPRB9220C0WW Washer
General Electric WPRB9220C1CC Washer
General Electric WPRB9220C1WW Washer
General Electric WPRB9220D0CC Washer
General Electric WPRB9220D0WW Washer
General Electric WPRB9220D1CC Washer
General Electric WPRB9220D1WW Washer
General Electric WPRB9220DCCC Washer
General Electric WPRB9220DCWW Washer
General Electric WPRB9250C0CC Washer
General Electric WPRB9250C0WW Washer
General Electric WPRB9250D0CC Washer
General Electric WPRB9250D0WW Washer
General Electric WPRB9250D1CC Washer
General Electric WPRB9250D1WW Washer
General Electric WPRE5240D1WW Washer
General Electric WPRE6100G0WT Washer
General Electric WPRE6100G1WT WASHER
General Electric WPRE6100G2WT WASHER
General Electric WPRE6100G3WT WASHER
General Electric WPRE6150H0WT WASHER
General Electric WPRE6150H1WT WASHER
General Electric WPRE6150H2WT WASHER
General Electric WPRE6150K0WT WASHER
General Electric WPRE6150K1WT WASHER
General Electric WPRE6150K2WT WASHER
General Electric WPRE6150K3WT WASHER
General Electric WPRE6280D1WW Washer
General Electric WPRE6280DCWW Washer
General Electric WPRE8100G0WT Washer
General Electric WPRE8100G1WT WASHER
General Electric WPRE8150H0WT WASHER
General Electric WPRE8150H1WT WASHER
General Electric WPRE8150H2WT WASHER
General Electric WPRE8150K0WT WASHER
General Electric WPRE8150K1WT WASHER
General Electric WPRE8150K2WT WASHER
General Electric WPRE8150K3WT WASHER
General Electric WPRE8320H2WT WASHER
General Electric WPRE8320H3WT WASHER
General Electric WPRE8350H0WT WASHER
General Electric WPRE8350H1WT WASHER
General Electric WPRE8350H2WT WASHER
General Electric WPSB8060B0CC Washer
General Electric WPSB8060B0WW Washer
General Electric WPSB8060B1CC Washer
General Electric WPSB8060B1WW Washer
General Electric WPSB8060B9CC Washer
General Electric WPSB8060B9WW Washer
General Electric WPSB9080B0CC Washer
General Electric WPSB9080B0WW Washer
General Electric WPSB9120B0CC Washer
General Electric WPSB9120B0WW Washer
General Electric WPSE3120Y1WW Washer
General Electric WPSE4200A0AA Washer
General Electric WPSE4200A0WW Washer
General Electric WPSE4270A0AA Washer
General Electric WPSE4270A0WW Washer
General Electric WPSE5290A0AA Washer
General Electric WPSE5290A0WW Washer
General Electric WPSE7001A0AA Washer
General Electric WPSE7001A0WW Washer
General Electric WPSE7002A0AA Washer
General Electric WPSE7002A0WW Washer
General Electric WPSE7003A0AA Washer
General Electric WPSE7003A0WW Washer
General Electric WPSE7003A1WW Washer
General Electric WPSE7003A9WW Washer
General Electric WPSE7003B9WW Washer
General Electric WPSF4170V0AA Washer
General Electric WPSF4170V0WW Washer
General Electric WPSF4170V1AA Washer
General Electric WPSF4170V1WW Washer
General Electric WPSF4170W0AA Washer
General Electric WPSF4170W0WW Washer
General Electric WPSF4170W1AA Washer
General Electric WPSF4170W1WW Washer
General Electric WPSF4170W2AA Washer
General Electric WPSF5170W0AA Washer
General Electric WPSF5170W0WW Washer
General Electric WPSF5170W1AA Washer
General Electric WPSF5170W1WW Washer
Whirlpool WPSHAW0 PURE DELIVERY WATER PUMP
General Electric WPSL3120W0WW Washer
General Electric WPSL3120W2WW Washer
General Electric WPSP4170W0WW Washer
General Electric WPSP4170W1WW Washer
General Electric WPSQ3120T2AA Washer
General Electric WPSQ3120T2WW Washer
General Electric WPSQ3120T5AA Washer
General Electric WPSQ3120T5WW Washer
General Electric WPSQ3120T6AA Washer
General Electric WPSQ3120T6WW Washer
General Electric WPSQ3120T8AA Washer
General Electric WPSQ3120T8WW Washer
General Electric WPSQ3120T9AA Washer
General Electric WPSQ3120T9WW Washer
General Electric WPSQ3120TAAA Washer
General Electric WPSQ3120TAWW Washer
General Electric WPSQ4160T2AA Washer
General Electric WPSQ4160T2WW Washer
General Electric WPSQ4160T5AA Washer
General Electric WPSQ4160T5WW Washer
General Electric WPSQ4160T6AA Washer
General Electric WPSQ4160T6WW Washer
  #2 (permalink)
Old 04-11-2011, 04:29 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
GE will not make its tech data public. There should be tech notes inside the machine that may help you, if not, try to talk to GE cause they won't talk to us.
__________________
  #3 (permalink)
Old 04-11-2011, 04:36 PM
Senior Expert
APP Volunteer
Default
Ok, here is what I found in a service manual on this model. Hope this helps.
Motor Assembly
• The washer has a direct drive pulse width modulation motor that does not utilize a belt, transmission, or mechanical brake.
• The motor assembly is composed of a coil wound stator, Hall sensor, and permanent magnet rotor.
• The motor varies speed and torque when the pulse width modulated voltage from the inverter changes frequency.
• The motor reverses rotational direction when the inverter reverses electrical polarity to the motor.
The washer motor has an approximate resistance value of 8 Ω between any two of the three wires:
• Blue to red - 8 Ω
• Red to yellow - 8 Ω
• Blue to yellow - 8 Ω
Resistance can be measured at the yellow, 3-pin connector on the inverter board or at the motor.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How To Check Continuity With Ohmmeter Admin / APP Team Oven Repair (including Ranges and Cooktops) 108 03-02-2018 12:07 PM
How To Check Washer Parts For Continuity Admin / APP Team Washer Repair 8 08-21-2015 02:18 PM
How To Check Dishwasher Parts For Continuity Admin / APP Team Dishwasher Repair 1 12-01-2008 08:32 PM
How To Check Refrigerator Parts For Continuity Admin / APP Team Refrigerator & Freezer Repair 11 10-13-2008 05:21 PM
