Hi, The washer quit in mid cycle and seems to be shutting off due to strain on the motor. when I unplug the unit the cord is very warm. The unit tries to engage yet shuts off within seconds. THANKS for your insight!
Probably something jammed in either the transmission, brakes, pump or between the tub and basket
:)Yep I bet your right! something jammed between the trans or something. that's what it acts like. Thanks again , Doug
