Discuss
whirlpool duet error code FH
 in
Washer Repair
whirlpool F/L duet washer error code FH, i find in many instances replacing a noisy pump resolves problem. what
Appliance Repair Forum > Appliance Repair Help > Washer Repair » whirlpool duet error code FH
  #1 (permalink)
Old 01-11-2009, 11:36 AM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default whirlpool duet error code FH
Brand: Whirlpool   Age: Less than 1 year
whirlpool F/L duet washer error code FH, i find in many instances replacing a noisy pump resolves problem. what have you guys experienced ? has there ever been any confusions with HF and what were your results +the steps you took to resolve it? thanks
__________________
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-11-2009, 02:40 PM
kayakcrzy kayakcrzy is offline
Senior Expert
APP Volunteer
kayakcrzy is on a distinguished road
Default
No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
• If there is water in the unit:
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
This is right from the manual. Tom ApplianceEducator.com
  #3 (permalink)
Old 01-11-2009, 03:27 PM
Senior Expert
APP Volunteer
Default
yes i have the manual, most eveything is suspect, what i would like to know is what part or parts do you personally mainly replace for this error code ,just out of curiosity, without referring me to manual
__________________
  #4 (permalink)
Old 01-11-2009, 06:06 PM
Senior Expert
APP Volunteer
Default
If the screans on the washer water valve are not clogged, an no water hot or cold are coming in, it is hard to tell from here. Most times both side of the valve do not go bad. So check the hot fill and the cold fill. If no water comes in, it will most likey be the control board. Tom ApplianceEducator.com
  #5 (permalink)
Old 01-11-2009, 07:49 PM
Senior Expert
APP Volunteer
Default
this is just a hypothetical question. through your own personal experience,what part is usualy at fault if a part is needed for FH error code.have you replaced more pumps or more flow meters or more ccu units or more pressure switches ,which of these parts have you replaced more often? thanks
__________________
  #6 (permalink)
Old 01-12-2009, 05:19 AM
Senior Expert
APP Volunteer
Default
More CCU units. I always carry a few with me. Tom ApplianceEducator.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
WhirlPool Duet dryer with 'E1' error theprof Dryer Repair 2 01-13-2009 06:45 AM
whirlpool duet error code FH misterfixall Washer Repair 7 01-08-2009 04:51 PM
Dreaded F06 error in Whirlpool Duet washer richappy Washer Repair 0 02-26-2008 04:20 AM
Whirlpool duet Error Code F30 mcjej@yahoo.com Washer Repair 0 11-24-2007 09:31 PM
Duet Sport F01 error Code vposton Washer Repair 2 09-15-2007 07:20 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
