| » Maytag Washer |
Model Number: MAV7000AWW Brand: -brand- Age: 1 - 5 years
My temperature control will only let me wash hot and rinse hot. Wont allow cold water to come into machine.
Well I do not understand how you are getting a hot rinse, since I don't think that is an option on this, or just about any other model. If you are getting hot water in the rinse cycle then it can be the water temp switch, the timer, the valve assembly or this part here particularly if you are getting hot water in the wash cycle when you have it set on cold water for wash.
Part number: AP4028021 My vote is for that board, but you will have to try replacing it to confirm that.
__________________
Quote:
I can NOT get any cold water to machine from any setting. Just replaced temp switch and still doing the same thing, Donna |
Just to add my 2 cents...
Donna, Did you check the incoming water hoses? They could be switched around. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Done that. The cold water side of the valve doesn't seem to be getting enough voltage to open. Does that come from the circuit board?
The board controls voltage to the valves. Take a look at the wiring diagram and you will see how it flows.
Wiring information replacement parts for MAYTAG MAV7000AWW WASHER, ATLANTIS | AppliancePartsPros.com
__________________
| Display Modes | |
| Maytag Washer | Richard Erickson | Washer Repair | 0 | 05-26-2010 05:06 PM |
| help how do you speciffically replace washer timer on Maytag washer | stupid1 | Washer Repair | 5 | 07-04-2009 05:21 PM |
| Maytag washer | cesarbazan | Washer Repair | 1 | 03-13-2009 07:32 PM |
| maytag washer/dyer combo washer no water | lindavanzandt | Washer Repair | 0 | 11-30-2008 08:35 AM |
| Maytag washer | washme | Washer Repair | 2 | 09-25-2007 05:51 PM |
