had a washer in shed, brung it in duriing winter months; connected washer and it filled with water, went thru wash cycle, started to spin then stopped. After 10 - 15 minutes it started to spin again but stopped. I believe I smell smoke. My father thinks I should let it thaw out and try later. However I believe motor is bad. Any reconmendations???
let it dry out ,may be motor
