Discuss
Noisy washer drain pump?
 in
Washer Repair
My 6 year old whirlpool washer works fine through all cycles, except when the water drains. There is a high
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Noisy washer drain pump?
  #1 (permalink)
Old 10-28-2007, 12:49 PM
mehullica mehullica is offline
Junior Member
mehullica is on a distinguished road
Default Noisy washer drain pump?
Model Number: lsr8233jq0   Brand: Whirlpool   Age: 1 - 5 years
My 6 year old whirlpool washer works fine through all cycles, except when the water drains. There is a high pitched noise as the water is being pumped out. The water does drain out, just really noisy. Is this a water pump issue? Or does the motor have 2 drive ends, one for the agiator side and one for the drain pump side that could be a problem also? Please someone help!--Thanks!!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-28-2007, 02:04 PM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Yep,
Check to see if you have something caught in the pump.
This video will show you how.
Video: How To Replace a Water Pump On A Whirlpool Made Direct Drive Washer
__________________
You can Repair your Appliance & we can help with our Appliance Repair Forum and Appliance Repair Blog.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch drain pump replacement Tom4852 Dishwasher Repair 3 10-03-2007 06:04 PM
washer noisy during spin djgabor Washer Repair 0 09-22-2007 01:03 PM
Washer won't drain during spin cycle. Water Pump Belt discovered on floor sandydjdm Washer Repair 1 08-14-2007 08:41 PM
Noisy Pump, Impeller Now Broken? metman Dishwasher Repair 5 08-11-2007 06:09 PM
Drain Pump loadster Dishwasher Repair 1 08-07-2007 07:35 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
