i have a whilpool cabrio that i just had the drain pump replaced. i was leaking water from the bottom oth the machine and giving an ol code. after replacing the pump, it stopped leaking but still gives the ol code. if i put it thru a wash cycle it will wash for a few minutes the skip to the rinse and finish the rinse and give the ol code. i was told it could be that there is too much corrosion in the inside of the tub and that it needs to be cleaned out! does anyone know if that is true and if so hoe do i remove the tub to do so!.
I am going to link you to a service manual that will describe the clean out procedure. It may be that water is not fully draining from the machine, and the new water being added trips the error code. It may be that the CCU is bad and is incorrectly showing the error code. https://secured.whirlpoo...540a8f/$FILE/8178582.pdf
