Discuss
Washer blows fuse when plugged in
 in
Washer Repair
My Maytag A7500 washing machine blows out it's fuse when it is plugged in. What is the most probable
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer blows fuse when plugged in
  #1 (permalink)
Old 01-09-2009, 11:40 PM
sysgroup sysgroup is offline
Junior Member
sysgroup is on a distinguished road
Question Washer blows fuse when plugged in
Model Number: A7500   Brand: Maytag   Age: More than 10 years
My Maytag A7500 washing machine blows out it's fuse when it is plugged in. What is the most probable cause (or causes) of this and what steps should I take to determine which parts are needed to correct this problem? Before it started blowing fuses it would occasionally quit between cycles until I pushed in the timer knob, turned it to another setting, and pulled out the knob again, then it even stopped responding to that tactic.
Related Models
Maytag A7500 Washer - Top Loading
Maytag A7500S Washer - Top Loading
Maytag A7500W Washer - Top Loading
Maytag A7800 Washer - Top Loading
Admiral A79E-5CXW Walloven - S/c Ele
Admiral A79F-5EXW-R Walloven - S/c Ele
Admiral A79FN-5EVW-R Walloven - S/c Ele
Frigidaire A7LECUD2 Frg(v19) / Room Air Conditioner
Maytag A806 Washer - Top Loading
Maytag A806S Washer - Top Loading
Maytag A810 Washer - Top Loading
Maytag A8100 Washer - Top Loading
Maytag A8120 Washer - Top Loading
Maytag A8140 Washer - Top Loading
Maytag A8200 Washer - Top Loading
Maytag A8210 Washer - Top Loading
Admiral A8210PA Surface Unit - Gas
Admiral A8210PA-L Surface Unit - Gas
Admiral A8210PT-L Surface Unit - Gas
Admiral A8210PW Surface Unit - Gas
Admiral A8210PW-L Surface Unit - Gas
Admiral A8211PA Surface Unit - Gas
Admiral A8211PS Surface Unit - Gas
Admiral A8211PW Surface Unit - Gas
Maytag A8240 Washer - Top Loading
Admiral A8241RA Surface Unit - Gas
Admiral A8241RA-L Surface Unit - Gas
Admiral A8241RS Surface Unit - Gas
Admiral A8241RT-L Surface Unit - Gas
Admiral A8241RV Surface Unit - Gas
Admiral A8241RW Surface Unit - Gas
Admiral A8241RW-L Surface Unit - Gas
Admiral A8261RB Surface Unit - Gas
Admiral A8261RV Surface Unit - Gas
Admiral A82LK-3K-R Surface Unit - Gas
Admiral A82LN-3K-R Surface Unit - Gas
Admiral A82LW-2K-R Surface Unit - Gas
Admiral A82R1RV Surface Unit - Gas
Admiral A8321PA Surface Unit - Gas
Admiral A8321PS Surface Unit - Gas
Admiral A8321PW Surface Unit - Gas
Admiral A8321TA-L Surface Unit - Gas
Admiral A8321TW-L Surface Unit - Gas
Maytag A8340 Washer - Top Loading
Maytag A8420 Washer - Top Loading
Maytag A8440 Washer - Top Loading
Maytag A8500 Washer - Top Loading
Maytag A8520 Washer - Top Loading
Maytag A8600 Washer - Top Loading
Admiral A8610PA Surface Unit - Ele
Admiral A8610PS Surface Unit - Ele
Admiral A8610PV Surface Unit - Ele
Maytag A8640 Washer - Top Loading
Maytag A8650 Washer - Top Loading
Admiral A8670PB Surface Unit - Ele
Admiral A8670PV Surface Unit - Ele
Admiral A86LW-1-R Surface Unit - Ele
Maytag A8700 Washer - Top Loading
Admiral A8720PA Surface Unit - Ele
Admiral A8720PW Surface Unit - Ele
Maytag A8740 Washer - Top Loading
Maytag A8800 Washer - Top Loading
Maytag A882 Washer - Top Loading
Maytag A8820 Washer - Top Loading
Maytag A882T Washer - Top Loading
Maytag A883 Washer - Top Loading
Maytag A883T Washer - Top Loading
Maytag A884 Washer - Top Loading
Maytag A8840 Washer - Top Loading
Maytag A884T Washer - Top Loading
Admiral A88FK-1 Surface Unit - Ele
Admiral A88FK-2-R Surface Unit - Ele
Admiral A88FK-6-R Surface Unit - Ele
Admiral A88FN-2-R Surface Unit - Ele
Admiral A88FN-2R Surface Unit - Ele
Admiral A88LK-6-R Surface Unit - Ele
Admiral A88LN-6-R Surface Unit - Ele
Admiral A89L-4-R Surface Unit - Ele
Frigidaire A8LECUD2 Frg(v20) / Room Air Conditioner
Frigidaire A8MECC2 Frg(v15) / Room Air Conditioner
Frigidaire A8MECD2 Frg(v21) / Room Air Conditioner
Frigidaire A8MECUC2 Frg(v16) / Room Air Conditioner
Frigidaire A8MECUC3 Frg(v17) / Room Air Conditioner
Frigidaire A8MECUSC2 Frg(v6) / Room Air Conditioner
Frigidaire A8MECUSC3 Frg(v7) / Room Air Conditioner
Maytag A900 Washer - Top Loading
Maytag A900S Washer - Top Loading
Maytag A902 Washer - Top Loading
Maytag A906 Washer - Top Loading
Jenn-Air A910 Misc / Accessory
Admiral A9122VPV Walloven - Std Gas
Maytag A9200 Washer - Top Loading
Admiral A9211XPB Walloven - Cont Clean Gas
Admiral A9222VPV Walloven - Cont Clean Gas
Admiral A9222XPB Walloven - Cont Clean Gas
Maytag A9300 Washer - Top Loading
Maytag A9400 Washer - Top Loading
Maytag A9400S Washer - Top Loading
Maytag A9400W Washer - Top Loading
Admiral A9475VRV Walloven - S/c Gas
Admiral A9475XRB Walloven - S/c Gas
Admiral A9495VRV Range - S/c Mwave Gas
Admiral A9495XRB Range - S/c Mwave Gas
Maytag A9600 Washer - Top Loading
Maytag A9700 Washer - Top Loading
Maytag A9700S Washer - Top Loading
Maytag A9700W Washer - Top Loading
Maytag A9800 Washer - Top Loading
Admiral A9814XPB Walloven - S/c Ele
Admiral A9845VPV Walloven - S/c Ele
Admiral A9845XPB Walloven - S/c Ele
Admiral A9854VPV Walloven - S/c Ele
Admiral A9854XPB Walloven - S/c Ele
Admiral A9875VRV Walloven - S/c Ele
Admiral A9875XRB Walloven - S/c Ele
Admiral A9895VRV Walloven - S/c Mwave Ele
Admiral A9895XRB Walloven - S/c Mwave Ele
Maytag A9900 Washer - Top Loading
General Electric A9B568DAALSA Zoneline
General Electric A9B568EPASSA Zoneline
  #2 (permalink)
Old 01-10-2009, 04:26 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Here is your parts breakdown
Model A7500
Here is a service manual
http://www.servicematters.com/maytag...s/16000131.pdf
Could be many things
Open up the control console and take look.
Sounds like you have a dead short somewhere.
Unplug it and measure across the line cord for resistance, if you get 0 ohms then you have a dead short for sure. Note you will need a decent meter to do this and set it at a low scale.
Try different timer settings, it may help localize the problem.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag blows 1 amp fuse TDBFIXIT Washer Repair 3 09-08-2008 05:08 AM
fuse blows donspicer1@hotmail.com Dryer Repair 9 08-09-2008 01:26 PM
Dryer Fuse Blows Often AL RYF Dryer Repair 1 06-24-2008 03:57 PM
fuse blows every time arcojet Dryer Repair 2 03-25-2008 06:30 AM
Blows Fuse on Startup pcfucci Microwave Repair 0 01-04-2008 08:16 PM
