Discuss
rust stains
 in
Washer Repair
We have College rental units and this stackable washer and dryer set are in most of them. We have a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » rust stains
  #1 (permalink)
Old 10-28-2007, 07:15 AM
yvonne yvonne is offline
Junior Member
yvonne is on a distinguished road
Default rust stains
Model Number: WSM2700TAW   Brand: GE   Age: 5 - 10 years
We have College rental units and this stackable washer and dryer set are in most of them. We have a problem with several of the dryers leaving rust stains on the clothes. I'm wondering if anyone has a diagnosis for this, or knows why or how this happens. Thanks, Yvonne
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-29-2007, 05:28 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
I think you have an anodized steel drum in these, they do not rust. If they are not anodized and rusty, the only solution I know is to remove the rust spots with emory paper at the beginning of rental, daily use will prevent rust buildup.
If anodized, you probably have worn drum front glides, Pn AP3156144.
__________________
  #3 (permalink)
Old 03-09-2008, 12:03 PM
rodney stanley rodney stanley is offline
Junior Member
rodney stanley is on a distinguished road
Default
The rust stains are actually from the felt type washer in the back of the dryer caused be accumulated dust. You need to sufficiently clean off the felt washer first.
  #4 (permalink)
Old 05-11-2008, 09:52 PM
emmagata emmagata is offline
Junior Member
emmagata is on a distinguished road
Default
Quote:
I have a Kenmore dryer that's leaving thin rust stains. We thought it was the washer but it wasn't. I discovered that the rust is coming from the felt washer between the rear bulkhead and the drum. It appears the clothes are getting pinched in the gap as they tumble. I looked up the parts but it would be pretty expensive to replace the parts (bulkhead, drum and felt washers). I was thinking about ripping it apart to see if the rust area can be repaired and then just replace the felt washer. I really hate have to replace it as it's only 8 years old (with just a 2 person household).
Any ideas? Thanks.
  #5 (permalink)
Old 05-12-2008, 04:16 AM
Senior Expert
APP Volunteer
Default
You need to pull the drum out and clean the back panel with comet cleanser, then replace the felt gasket.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
