Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Whirlpool Duet Washer front tub repair (http://forum.appliancepartspros.com/washer-repair/199679-whirlpool-duet-washer-front-tub-repair.html)
BPWAY 04-03-2011 06:40 PM
Just took apart our whirlpool duet washer model GHW9160PW0 due to the front tub separating from the basket. It was taken apart from the front. I am shocked at the mold on the outside of the basket and rear tub. The bearing looks ok but I will need to order the front tub part 8181825. I also need 2 or 3 clamps from the shock absorber, can you order just the clamps? I only see part 8181646 which seems like the entire thing.
Also when I put it back together and attach the basket to the springs, is this done from front of the washer or do I need to take the back off also?
Will whirlpool even cover any of these parts? I'm shocked that it broke already and how bad it smells! Is that normal for so much mold and detergent build up to be in the back of the tub?
Joe / APP Team 04-04-2011 10:19 AM
BP,
Don't quite inderstand "2 or 3 clamps for the shock absorber"
REMOVING THE SHOCK ABSORBERS
The tub is held in position by four shock absorbers,
two in front, and two at the back.
Each shock absorber can be disconnected from
the tub by turning the top of the shock mount
counter clockwise, 90°. The shock can be removed
from the washer by turning the bottom
shock mount counterclockwise, 90°.
Yes, it is not uncommon to have a build up residue and "mold" in the rear of the outer tub, and in some cases on the tub front cover.
It's also an indication of too much detergent or the improper type of detergent and chemical usage. but there is a cleaning product available for this situation.
Part number: AP4320043
All the repairs you're indicating can be performed from the front of the washer, but the rear shocks will be a bit difficult, and you may want to remove the rear panel.
If your washer is more than 1 year old, you're out of the factory warranty, but you may want to give it a "shot", it can't hurt.
BPWAY 04-05-2011 12:29 PM
Thanks for all the info! The clamps are actually the top grey piece on the shock absorber. I broke two of them trying to get it out so I wasn't sure if I can buy just two grey pieces or if I need to buy the entire shock absorber.
Joe / APP Team 04-05-2011 02:59 PM
Quote:
BP,
Now I understand, Sorry, but you'll need to order the complete assembly, two of them.
(click on part number for additional information)
Part number: AP3868181
Thanks and Good Luck
BPWAY 04-27-2011 05:29 PM
Service Manual
Is there a service manual available that I can reference?
Joe / APP Team 04-28-2011 06:30 AM
Quote:
BPWAY,
Here's the part number for the service manual, you would use as a reference,
Part number: AP3958562
If you need something specific, we can attempt to extract it from the manual and attach it to a post response, as we did before.
dom12345 05-05-2011 07:54 PM
how hard is it to replace outter tub?
dom12345 05-05-2011 07:58 PM
I need to change otter tub on a whirlpool ghw9400pwo how hard is it?
Joe / APP Team 05-06-2011 06:17 AM
Quote:
Dom,
It's not a "hard" repair, just time consuming and cumbersome, you need lots of room, you'll basically have an empty cabinet,after the teardown, and will re fill it. In most cases I would think a DIY'r would take a couple of hours on average to do the repair. Basic handtools and a "socket set" will get you through the repair.
I take for granted you'll need the rear outer tub assembly, bad bearings, probably ?
Good Luck,
