| » Older Kenmore washer appears "dead"! |
Model Number: 110.72625100 Brand: Kenmore Age: More than 10 years
Machine stopped while pumping out rinse water.
I manually emptied most of the remaining water. Checked outlet, has 120v power. When timer is manually advanced, nothing happens. No hum from timer. Checked door switch, it ohmed out okay. Is there a fuse on the door switch circuit on this model? Would any of the settings function if the timer motor is shot? Do you think the timer needs replaced, or should I keep troubleshooting? Can you tell me which wires on the harness are the power supply? Perhaps it is not getting power to the timer. Do you have any other suggestions I could try before throwing parts at it?!!!!! Thanks, Cappy |
| Display Modes | |
| "CLEAN" cycle light always flashing | Tadek | Dishwasher Repair | 9 | 07-22-2008 06:01 PM |
| Starts cycle, gets "stuck" with h2o in bottom, timer is still heard-lights on too. | julialovesjohn | Dishwasher Repair | 1 | 10-03-2007 08:16 PM |
| Only freezes in "quick freeze" mode | alraybonsue | Refrigerator & Freezer Repair | 0 | 09-23-2007 08:10 PM |
| Dispencer "flap" sticking open | mommom02 | Refrigerator & Freezer Repair | 0 | 08-31-2007 12:02 PM |
| Oven oesn't bake/heat and displays a "FS" error message | jnymdnyt | Oven Repair (including Ranges and Cooktops) | 5 | 08-06-2007 07:36 PM |
