I need to change the cold water valve (no water, no hum) on this 2003 washing machine. Can someone walk me thru the proper way to get to the valve. I do not have a manual.
Really appreciate some time saving help before I start disassembling. Thanks
You have to remove the washer cabinet to access the water valve. The instructions are attached. - The part number for the water mixing valve is AP3094541Here are the break down diagrams for the Roper washer Model RAX4232KQ0Gene.
Gene, thank you very much for your help and instructions.
