Discuss
Maytag wash won't spin on regular cycle but will on gentle cycle
 in
Washer Repair
In Regular mode, the washer runs through the rinse cycle, fills up with water, then should drain as it spins.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag wash won't spin on regular cycle but will on gentle cycle
  #1 (permalink)
Old 01-07-2009, 08:41 PM
Junior Member
BlazingSun is on a distinguished road
Default Maytag wash won't spin on regular cycle but will on gentle cycle
Model Number: 2 speed heavy duty top loader   Brand: Maytag   Age: More than 10 years
In Regular mode, the washer runs through the rinse cycle, fills up with water, then should drain as it spins. The spin does not start so the timer moves on and gets to the end of the cycle, leaving a tub full of water.
There are three modes, Regular, Permanent Press and Gentle. Regular and Permanent Press have the problem. If I move the dial to the Gentle cycle, it will spin up and drain just fine.
When I move the dial to spin on Regular and Permanent Press cycles, there is a short (1 sec or less) thump (like the motor takes a power hit to try and spin) but nothing happens.
This is a Maytag 2 speed top loader so I'm guessing that something is wrong with the Regular speed and the Gentle speed is OK.
Any help will be most appreciated.
Ads By Google
Related Models
Amana 20 Freezer - Vertical
Amana 200.000 Mwave - Family Size (60 Hz)
Amana 200.001 Mwave - Family Size (60 Hz)
Hoover 2000 Frigidaire/electric Range
Hoover 2001 Frigidaire/walloven
Amana 2008.000 Mwave - Family Size (60 Hz)
Amana 2008.001 Mwave - Family Size (60 Hz)
Amana 2008.002 Mwave - Family Size (60 Hz)
Amana 2008.004 Mwave - Family Size (60 Hz)
Amana 2008.100 Commercial Microwaves
Amana 2008.101 Commercial Microwaves
Amana 2008.102 Commercial Microwaves
Amana 2008.112 Commercial Microwaves
Amana 2009.000 Mwave - Family Size (60 Hz)
Amana 2009.001 Mwave - Family Size (60 Hz)
Amana 2009.002 Mwave - Family Size (60 Hz)
Amana 2009.004 Mwave - Family Size (60 Hz)
Amana 200A-30 Room Air Conditioner
Amana 200A-30H Room Air Conditioner
Amana 200A-3HN Room Air Conditioner
Amana 200A-3M Room Air Conditioner
Amana 200A-3N Room Air Conditioner
Amana 200A-3P Room Air Conditioner
Amana 200A-3PH Room Air Conditioner
Amana 200A-3R Room Air Conditioner
Amana 200A-3RH Room Air Conditioner
Amana 200C-30
Amana 200C-30H
Amana 200C-3P Room Air Conditioner
Amana 200C-3PH Room Air Conditioner
Amana 200C-3R Room Air Conditioner
Amana 200C-3RH Room Air Conditioner
Amana 200C-8P Room Air Conditioner
Amana 200C-8RH Room Air Conditioner
Amana 200S
Amana 200SA
Amana 201.000 Mwave - Family Size (60 Hz)
Amana 201.001 Mwave - Family Size (60 Hz)
Amana 201.700 Mwave - Family Size (60 Hz)
Hoover 2010 Frigidaire/range
Hoover 2011
Jenn-Air 20135 Range - S/c D/i Ddraft Ele
Hoover 2017 Tappan/range
Amana 2018.000 Mwave - Family Size (60 Hz)
Amana 2018.001 Mwave - Family Size (60 Hz)
Amana 2018.002 Mwave - Family Size (60 Hz)
Amana 2018.004 Mwave - Family Size (60 Hz)
Amana 2022.000 Mwave - Family Size (60 Hz)
Amana 2022.001 Mwave - Family Size (60 Hz)
Amana 2022.002 Mwave - Family Size (60 Hz)
Amana 2022.004 Mwave - Family Size (60 Hz)
Jenn-Air 20236 Range - S/c S/i Ddraft Ele
Jenn-Air 20237 Range - S/c S/i Ddraft Ele
Jenn-Air 20239 Range - S/c S/i Ddraft Ele
Whirlpool 2025B0A
Whirlpool 2035B0A
Amana 2036.001 Mwave - Family Size (60 Hz)
Amana 2036.005 Mwave - Family Size (60 Hz)
Amana 2036.104 Commercial Microwaves
Amana 2036.105 Commercial Microwaves
Amana 2039.000 Mwave - Family Size (60 Hz)
Amana 2039.001 Mwave - Family Size (60 Hz)
Amana 2039.002 Mwave - Family Size (60 Hz)
Amana 2039.004 Mwave - Family Size (60 Hz)
Hoover 2040
Whirlpool 2041B10
Whirlpool 2041B20
Whirlpool 2041B30
Whirlpool 2041B40
Whirlpool 2045B0A
Whirlpool 2045B1A
Hoover 2048 Frigidaire/warmer Drawer
Amana 2052.000 Mwave - Family Size (60 Hz)
Amana 2052.001 Mwave - Family Size (60 Hz)
Amana 2052.002 Mwave - Family Size (60 Hz)
Amana 2052.004 Mwave - Family Size (60 Hz)
Amana 2054.000 Mwave - Family Size (60 Hz)
Amana 2054.001 Mwave - Family Size (60 Hz)
Amana 2054.002 Mwave - Family Size (60 Hz)
Amana 2054.004 Mwave - Family Size (60 Hz)
Whirlpool 2055B0A
Whirlpool 2055B1A
Whirlpool 2055B2A
Whirlpool 2065B0A
Whirlpool 2065B1A
Whirlpool 2065B2A
Whirlpool 2068120
Whirlpool 2068130
Whirlpool 2068160
Amana 2070.000 Mwave - Family Size (60 Hz)
Amana 2070.001 Mwave - Family Size (60 Hz)
Amana 2070.002 Mwave - Family Size (60 Hz)
Amana 2070.004 Mwave - Family Size (60 Hz)
Amana 2071.004 Mwave - Family Size (60 Hz)
Amana 2072.000 Mwave - Family Size (60 Hz)
Amana 2072.001 Mwave - Family Size (60 Hz)
Amana 2072.002 Mwave - Family Size (60 Hz)
Amana 2072.004 Mwave - Family Size (60 Hz)
Amana 2074.000 Mwave - Family Size (60 Hz)
Amana 2074.001 Mwave - Family Size (60 Hz)
Amana 2074.002 Mwave - Family Size (60 Hz)
Amana 2074.004 Mwave - Family Size (60 Hz)
Whirlpool 2075B0A
Whirlpool 2075B1A
Whirlpool 2075B2A
Whirlpool 2079B00
Whirlpool 2079B10
Whirlpool 2079B20
Whirlpool 2079B30
Whirlpool 2079B40
Amana 2085.000 Mwave - Family Size (60 Hz)
Amana 2085.001 Mwave - Family Size (60 Hz)
Amana 2085.002 Mwave - Family Size (60 Hz)
Amana 2085.004 Mwave - Family Size (60 Hz)
Amana 2089.004 Mwave - Family Size (60 Hz)
Amana 2090.000 Mwave - Family Size (60 Hz)
Amana 2090.001 Mwave - Family Size (60 Hz)
Amana 2090.002 Mwave - Family Size (60 Hz)
Amana 2091.004 Mwave - Family Size (60 Hz)
Amana 2092.004 Mwave - Family Size (60 Hz)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Will not Spin/Drain in Knit/Gentle Cycle RobertH Washer Repair 0 03-02-2009 07:37 AM
Washer will not go through rinse or spin cycle on regular cycle dhilde7165 Washer Repair 0 02-14-2009 04:10 PM
Gentle cycle/slow spin speed problem WFH Washer Repair 1 01-19-2008 08:17 PM
No spin on regular cycle, others work klawson Washer Repair 2 12-05-2007 02:58 PM
Maytag Performa Washer won't spin or wash on regular cycle gidy34 Washer Repair 1 11-14-2007 09:54 AM
