| » Amana Washing machine noise |
Model Number: NAV2335AWW Brand: Amana Age: 1 - 5 years
My washing machine started making a squeaking noise about two weeks ago, it only does it on the agitation cycle the spin cycle is perfect, it sound like a belt slip, but i was wanting to make sure there isn't bigger problems any help would be much appreciated
Tilt the washer back and remove the belt, replace if slick. Check the tranny and motor pulley's for burnt marks, then check the pump for bad bearings. Post results. Belt AP4024823, tranny pulley AP4009132, pump AP4025157
__________________
- Last edited by richappy : 01-16-2009 at 02:01 AM. |
Mine just started this squeak too - seems common. Check out this video, the guy has the exact same problem: YouTube - Amanatag Washing Machine Squeak
I played this video and my wife started laughing because the noise is the exact same. My belt seems okay but there is evidence of something rubber grinding at the base of the washer - lots of black "rubber dust" All else seems fine. I've read that this washer is also prone to tub seal problems. I'm going to try lubricating the brake pads first and I'll post the results. |
I have an Amana NAV5805AWW. It is about 4 years old and gently used. It stated making a belt slip noise during the wash cycle only. I replaced the belt. I noticed that it appears the motor slide mechanism does not tighten the belt as tight in the wash cycle as it does in the spin cycle. I cleaned the slide up and even applied a little silicone to the slide area. Has anybody else experienced this and have a fix? Thanks
| Display Modes | |
| Washing machine noise | bama09 | Washer Repair | 5 | 01-20-2010 06:49 PM |
| Amana Turbo 210 washing machine | rileys | Washer Repair | 2 | 08-14-2009 12:45 PM |
| Washing Machine Noise | scrappy32008 | Washer Repair | 0 | 07-31-2009 08:45 PM |
| Amana top loader washing machine mixing valve | anna53 | Washer Repair | 1 | 06-14-2009 11:31 AM |
| Washing Machine Noise In Spin | jim@BANCENTRE.COM | Washer Repair | 3 | 11-10-2008 01:05 PM |
