Discuss
water shut off to washer but it still fills
 in
Washer Repair
I have an Admiral 20 lb washer which is at least 11 years old. We have newer hoses that were
Appliance Repair Forum > Appliance Repair Help > Washer Repair » water shut off to washer but it still fills
  #1 (permalink)
Old 03-31-2011, 03:34 PM
Junior Member
jammjm is on a distinguished road
Default water shut off to washer but it still fills
Model Number: unsure   Brand: Admiral   Age: More than 10 years
I have an Admiral 20 lb washer which is at least 11 years old. We have newer hoses that were attached by our plumber along with easy to use shut-off valves. We are very careful about shutting off the water after we are finished using the machine.
We used the washer Sunday. Today, Thursday I went to run a load and there were a few inches of clean-smelling water in the washer. I ran a quick spin to get it to drain then used the washer normally.
I just checked it now, 8 hours later and it is dry.
Is this a inlet valve issue? That doesn't seem likely to me since the water is off at the pipe. I don't know that it is the drain either since the water smells and looks clear.
How do I test either of these things? Any help would be greatly appreciated.
Ads By Google
Related Models
Maytag UNVIM98 Misc / Accessory
Amana URC517MP Commercial Microwaves
Amana URCS511 Commercial Microwaves
Amana URCS511A  Commercial Microwaves
Amana URFS511 Commercial Microwaves
Amana URFS518S  Commercial Microwaves
Amana URS511 Commercial Microwaves
Amana URS511M Commercial Microwaves
Amana URS511MB  Commercial Microwaves
Amana URS511P  Commercial Microwaves
Menu Master US11EA  Commercial Microwaves
Maytag UXA1000AAB Misc / Accessory
Maytag UXA1000AAP Misc / Accessory
Maytag UXA1000AAQ Misc / Accessory
Maytag UXA1000AAW Misc / Accessory
Maytag UXA1027ADB Misc / Accessory
Maytag UXA1027ADQ Misc / Accessory
Maytag UXA1027ADW Misc / Accessory
Maytag UXA1030ADB Misc / Accessory
Maytag UXA1030ADQ Misc / Accessory
Maytag UXA1030ADW Misc / Accessory
Jenn-Air UXA9007AAB Misc / Accessory
Jenn-Air UXA9007AAQ Misc / Accessory
Jenn-Air UXA9007AAW Misc / Accessory
Maytag UXT2030AAB Hood
Maytag UXT2030AAQ Hood
Maytag UXT2030AAS Hood
Maytag UXT2030AAW Hood
Maytag UXT2036AAB Hood
Maytag UXT2036AAQ Hood
Maytag UXT2036AAS Hood
Maytag UXT2036AAW Hood
Maytag UXT3030AAB Hood
Maytag UXT3030AAQ Hood
Maytag UXT3030AAS Hood
Maytag UXT3030AAW Hood
Maytag UXT3036AAB Hood
Maytag UXT3036AAQ Hood
Maytag UXT3036AAS Hood
Maytag UXT3036AAW Hood
Maytag UXT4030AAB Hood
Maytag UXT4030AAQ Hood
Maytag UXT4030AAS Hood
Maytag UXT4030AAW Hood
Maytag UXT4036AAB Hood
Maytag UXT4036AAQ Hood
Maytag UXT4036AAS Hood
Maytag UXT4036AAW Hood
Maytag UXT5230ADB Hood
Maytag UXT5230ADQ Hood
Maytag UXT5230ADS Hood
Maytag UXT5230ADW Hood
Maytag UXT5236ADB Hood
Maytag UXT5236ADQ Hood
Maytag UXT5236ADS Hood
Maytag UXT5236ADW Hood
Maytag UXT5430ADB Hood
Maytag UXT5430ADQ Hood
Maytag UXT5430ADS Hood
Maytag UXT5430ADW Hood
Maytag UXT5436ADB Hood
Maytag UXT5436ADQ Hood
Maytag UXT5436ADS Hood
Maytag UXT5436ADW Hood
Thermador V-206
Thermador V-207
Thermador V-6
Thermador V-QT-200
Thermador V-QT-300
Thermador V-QT-400
Thermador V-QT-90
Whirlpool V125
Whirlpool V135
Frigidaire V13A Frg(v1) / Upright Freezer
Frigidaire V13B Frg(v2) / Upright Freezer
Whirlpool V140
Whirlpool V150
Frigidaire V16A Frg(v1) / Upright Freezer
Frigidaire V16B Frg(v2) / Upright Freezer
Frigidaire V16C Frg(v3) / Upright Freezer
Frigidaire V21A Frg(v1) / Upright Freezer
Frigidaire V21B Frg(v2) / Upright Freezer
Frigidaire V21C Frg(v3) / Upright Freezer
Amana VA2013 Washer - Top Loading
Amana VA4013 Washer - Top Loading
Amana VA6013 Washer - Top Loading
General Electric VBSR1070T2AB Washer
General Electric VBSR1070T2WB Washer
General Electric VBSR1070T3AB Washer
General Electric VBSR1070T3WB Washer
General Electric VBSR1070T4AB Washer
General Electric VBSR1070T4WB Washer
General Electric VBSR1070T5AB Washer
General Electric VBSR1070T5WB Washer
General Electric VBSR1070T5WW Washer
General Electric VBSR1070T8WW Washer
General Electric VBSR1070TAWW Washer
General Electric VBSR2060V1AA Washer
General Electric VBSR2060V1WW Washer
General Electric VBSR2080W0AA Washer
General Electric VBSR2080W0WW Washer
General Electric VBSR2080W1AA Washer
General Electric VBSR2080W1WW Washer
General Electric VBSR3100B0WW Washer
General Electric VBSR3100B2WW Washer
General Electric VBSR3100B3WW Washer
General Electric VBSR3100D0WW Washer
General Electric VBSR3100D5WW Washer
General Electric VBSR3100DAWW Washer
General Electric VBSR3100DBWW Washer
General Electric VBSR3100DCWW Washer
General Electric VBSR3100G0WW Washer
General Electric VBXR106072WB Refrigerator
General Electric VBXR1060T2AB Washer
  #2 (permalink)
Old 04-02-2011, 05:22 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Since you shut off water to the machine, I think what happened was that the tub did not drain completely from your previous wash, and that was the source of the water that you found.
The next run may have cleared out a small blockage, so keep checking after each wash and if the tub is empty you should be fine.
__________________
  #3 (permalink)
Old 04-03-2011, 06:39 AM
Junior Member
Default
Thanks for the input. That wasn't the issue, though. We had someone over to take a look and there's an issue with the backflow valve in the waste line.
  #4 (permalink)
Old 04-03-2011, 07:27 AM
Senior Expert
APP Volunteer
Default
Well that will do it. Unusual that water would back up so much to flow back into the tub, but seems like it can happen. Hope you got it corrected ok and thanks for the update.
__________________
  #5 (permalink)
Old 04-03-2011, 09:37 AM
Junior Member
Default
I know, it seemed odd to me, too. But apparently our plumbing isn't the greatest setup (nothing in our house is!) so the dishwasher and kitchen sink, which are a floor up from the washer in the basement all drain into the same waste pipe. Like I said, not the greatest setup.
Again, thanks for your input!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer fills with water when OFF tballard Washer Repair 2 03-01-2010 07:43 AM
Washer fills with water when OFF tballard Washer Repair 1 02-19-2010 06:33 PM
washer fills with water by itself michele1234 Washer Repair 7 05-05-2009 09:08 AM
Water level does not shut off/ and it fills with water & drains but does not agitate dogwood100 Washer Repair 1 04-14-2009 05:20 PM
washer fills with water but does nothing after that threads68 Washer Repair 0 06-06-2008 01:59 PM
