Discuss
bellows seal in compact Whirlpool
 in
Washer Repair
Hello, I am replacing the bellow(s) seal in the door of my washer because it was so moldy I couldn't
Appliance Repair Forum > Appliance Repair Help > Washer Repair » bellows seal in compact Whirlpool
  #1 (permalink)
Old 03-31-2011, 09:33 AM
Junior Member
dweller is on a distinguished road
Default bellows seal in compact Whirlpool
Model Number: LHW0050PQ3   Brand: Whirlpool   Age: 1 - 5 years
Hello,
I am replacing the bellow(s) seal in the door of my washer because it was so moldy I couldn't clean it. Instructions from another site told me to remove the front panel and kick plate, but they are spot-welded on. The space is so tight with the front panel in place that I can't get enough leverage to push the tube from the seal through the hole it goes into. Any suggestions? I also need advive about cleaning out the mold in the rest of the machine.l
Thanks,
Paul
Related Models
Whirlpool LHW0050PQ3 COMPACT AUTOMATIC WASHER
Whirlpool LHW0050PQ4 COMPACT AUTOMATIC WASHER
General Electric LISR310CW0WW Washer
General Electric LISR310CW1WW Washer
Whirlpool LJD1306LQ0
Whirlpool LJD1306LT0
Bosch LK100-010
Bosch LK100-020
Bosch LK100-110
Bosch LK100-120
Bosch LK320-010
Bosch LK320-020
Bosch LK320-030
Bosch LK400-010
Bosch LK400-020
Bosch LK400-030
Amana LKG-170 ROOM AIR CONDITIONER
Amana LKG-171 ROOM AIR CONDITIONER
Amana LKG-240 ROOM AIR CONDITIONER
Amana LKG-240H ROOM AIR CONDITIONER
Amana LKG-241 ROOM AIR CONDITIONER
Amana LKG-241H ROOM AIR CONDITIONER
Amana LKG-300 ROOM AIR CONDITIONER
Amana LKG-300H ROOM AIR CONDITIONER
Amana LKG-340 ROOM AIR CONDITIONER
Amana LKG-340HE ROOM AIR CONDITIONER
Amana LKG-341 ROOM AIR CONDITIONER
Amana LKG-470 ROOM AIR CONDITIONER
Amana LKG-470HE ROOM AIR CONDITIONER
Amana LKG-471 ROOM AIR CONDITIONER
Amana LKG-471HE ROOM AIR CONDITIONER
Amana LKG-621 ROOM AIR CONDITIONER
Amana LKG601-617 ROOM AIR CONDITIONER
Amana LKG601H-617 ROOM AIR CONDITIONER
Amana LKI721 RANGE- F/S STD GAS
Amana LKU-617 RANGE- S/C S/I DDRAFT GAS
Amana LKU-617A RANGE- S/C S/I DDRAFT GAS
Bosch LL010-000
Whirlpool LLC7244AN0
Whirlpool LLC7244AQ0
Whirlpool LLC7244AW0
Whirlpool LLC7244AZ0
Whirlpool LLC7244BQ0
Whirlpool LLC7244BQ1
Whirlpool LLC7244BZ0
Whirlpool LLC7244BZ1
Whirlpool LLC8244DQ0
Whirlpool LLC8244DZ0
Whirlpool LLN8233BN0
Whirlpool LLN8233BN1
Whirlpool LLN8233BQ0
Whirlpool LLN8233BQ1
Whirlpool LLN8233BW0
Whirlpool LLN8233BW1
Whirlpool LLN8244AN0
Whirlpool LLN8244AW0
Whirlpool LLN8244BN0
Whirlpool LLN8244BW0
Admiral LLR1100AJQ RANGE- F/S STD GAS
Admiral LLR1100AJW RANGE- F/S STD GAS
Admiral LLR1415AJS RANGE- F/S STD GAS
Admiral LLR1415AJW RANGE- F/S STD GAS
Admiral LLR4451AJS RANGE- F/S STD GAS
Admiral LLR4451AJW RANGE- F/S STD GAS
Whirlpool LLR5144BQ0
Whirlpool LLR5144BQ1
Whirlpool LLR5144BW0
Whirlpool LLR6144AN0
Whirlpool LLR6144AQ0
Whirlpool LLR6144AW0
Whirlpool LLR6144BN0 WASHER
Whirlpool LLR6144BN1 AUTOMATIC WASHER
Whirlpool LLR6144BQ0 WASHER
Whirlpool LLR6144BQ1 AUTOMATIC WASHER
Whirlpool LLR6144BW0 WASHER
Whirlpool LLR6233AN0
Whirlpool LLR6233AN1
Whirlpool LLR6233AQ0
Whirlpool LLR6233AW0
Whirlpool LLR6233AW1
Whirlpool LLR7144DQ0
Whirlpool LLR7144DW0
Whirlpool LLR7144DZ0
Whirlpool LLR8233BN0 AUTOMATIC WASHER
Whirlpool LLR8233BN1 AUTOMATIC WASHER
Whirlpool LLR8233BQ0 AUTOMATIC WASHER
Whirlpool LLR8233BQ1 AUTOMATIC WASHER
Whirlpool LLR8233BW0 AUTOMATIC WASHER
Whirlpool LLR8233BW1 AUTOMATIC WASHER
Whirlpool LLR8233DQ0 AUTOMATIC WASHER
Whirlpool LLR8233DW0 AUTOMATIC WASHER
Whirlpool LLR8233DZ0 AUTOMATIC WASHER
Whirlpool LLR8233EQ0 AUTOMATIC WASHER
Whirlpool LLR8233EQ1 DIRECT-DRIVE WASHER
Whirlpool LLR8233EZ0 AUTOMATIC WASHER
Whirlpool LLR8233EZ1 DIRECT-DRIVE WASHER
Whirlpool LLR8245AW0 Washers
Whirlpool LLR8245BN0 AUTOMATIC WASHER
Whirlpool LLR8245BN1 AUTOMATIC WASHER
Whirlpool LLR8245BW0 AUTOMATIC WASHER
Whirlpool LLR8245BW1 AUTOMATIC WASHER
Whirlpool LLR8245DQ0 AUTOMATIC WASHER
Whirlpool LLR8245DZ0 AUTOMATIC WASHER
Whirlpool LLR9245AQ0
Whirlpool LLR9245BQ0
Whirlpool LLR9245BQ1 WASHERS DIRECT-DRIVE
Whirlpool LLR9245DQ0
Whirlpool LLR9245DQO WHIRLPOOL WASHER
Whirlpool LLR9245DZ0
Whirlpool LLR9245DZO WHIRLPOOL WASHER
Whirlpool LLT7144AN0 Washers*
Whirlpool LLT7144BN0
Whirlpool LLT7144BQ0
Whirlpool LLT7144BQ1
Whirlpool LLT7144BW0
Whirlpool LLT7144DQ0
Whirlpool LLT8233AN0
Whirlpool LLT8233AQ0
Whirlpool LLT8233AW0
Whirlpool LLT8233AW1 AUTOMATIC WASHER
  #2 (permalink)
Old 04-01-2011, 07:16 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Here is a link to the service manual for your model.
https://secured.whirlpool.com/Servic.../WPWASHER1.pdf
As for the mildew, I suggest you call APP and ask them about washer cleaning products they stock which may help you with the mildew. I would also contact Whirlpool even if the machine is out of warranty and this can be a severe problem; it has already been the downfall of many a front loading model.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer bellows dlucky Washer Repair 0 04-24-2010 11:45 PM
Whirlpool Duet Replacing Bellows (part AP3597347) cybersaint2k Washer Repair 3 01-08-2010 12:03 PM
Front bellows seal. tuslogdet27 Washer Repair 7 03-31-2009 08:29 AM
replace Bellows David Monholland Washer Repair 1 02-25-2009 06:05 PM
Changing door bellows on Whirlpool duet sport jdpierce Washer Repair 0 08-28-2008 09:39 AM
