Discuss
Tub Unbalanced
 in
Washer Repair
Tub unbalanced, checked and the only problem that was found was there are two plastic catch cups with a brass
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Tub Unbalanced
  #1 (permalink)
Old 10-27-2007, 10:38 AM
skipper skipper is offline
Junior Member
skipper is on a distinguished road
Angry Tub Unbalanced
Model Number: 110.23832100   Brand: Kenmore   Age: 5 - 10 years
Tub unbalanced, checked and the only problem that was found was there are two plastic catch cups with a brass pin laying in one of the, are they suppoed to go up through the tub mounts. I took the cups off and fixed without cups, there was improvement. Spins okay when it starts but it becomes unbalanced after about 30 seconds??????
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-27-2007, 10:41 AM
Junior Member
Default
Washer pump works fine.
  #3 (permalink)
Old 10-27-2007, 10:52 AM
fixxit fixxit is offline
Senior Expert
APP Volunteer
fixxit is on a distinguished road
Default
the cup you mention are the catch cup for the shipping pins. you do not want the shipping pins in when you are using the washer, only when shipping. as a matter of fact make sure the pins are out. the next this to check are the springs, there are 3 aroung the tub and a counter balance one at the rear, usualy the counter balance spring wears out or wears through on older machines. if worn through you can, make a new one. small guage bit fairly close to the original hole. check the springs and post your findings. good luck
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer noise on spin cycle...not unbalanced load marykelly7 Washer Repair 3 08-12-2007 09:50 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
