I replaced the dogs in my agitator, put it back together, it works but makes a terrible noise. Bottom part doesn't seem to be working right, what did I do wrong???:mad:
Originally Posted by: kbarker01 I replaced the dogs in my agitator, put it back together, it works but makes a terrible noise. Bottom part doesn't seem to be working right, what did I do wrong???:mad: K, Did you notice if the splines inside the lower agitator (underside ) were stripped or smooth ? Did you install the complete repair kit ? Are you sure, you installed the agitator mounting bolt down the center of the opening in the auger assembly and is it tight ? That's about all I can think of at this time. :) :) :)
