| » Is it the Washer Pump |
Model Number: FWX233RES3 Brand: Frigidaire Age: 5 - 10 years
Hello,
Well the washer is now making a high pitched noise when it is trying to drain during the wash and rinse cycle and is not draining the water completely. During these times it is not spinning well and I am assuming it is because of to much water. The spin cyle is working well and spinning fast however I usually have to spin a load at least twice before I am able to dry it. Sounds like it is the pump however the high pitch noise is throwing me off a little. Any suggestions. Ads By Google Related Models |
often times the pump cloggs or the pump motor wears out. you may have more problems but lets tackle the poor draining first as it sounds like a big offender. if all the water is out of the tub use a bucket or wet/dry shop vac to catch the rest of the water out of the lines. once that is done. disconnect the drain pump electrical leads and try to put it into a spin cycle. this will tell you if it some thing other than just the pump. post you results. good luck
| Display Modes | |
| washer will pump but not spin | neetalouise | Washer Repair | 1 | 07-16-2009 03:35 PM |
| Frigidaire washer pump | Ripley | Washer Repair | 1 | 07-08-2009 04:04 PM |
| washer pump | mom01 | Washer Repair | 7 | 03-29-2009 08:50 AM |
| washer pump | buzzard | Washer Repair | 1 | 03-05-2009 09:02 AM |
| Bosch washer pump issue (already replaced pump!) | wdt | Washer Repair | 0 | 12-02-2008 06:26 AM |
