Discuss
Replace baffles
 in
Washer Repair
I need to replace 1 of the baffles in this drum, I already purchased the part from you guys. I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Replace baffles
  #1 (permalink)
Old 03-30-2011, 05:51 PM
Junior Member
bmattila is on a distinguished road
Default Replace baffles
Brand: Kitchen Aid   Age: 1 - 5 years
I need to replace 1 of the baffles in this drum, I already purchased the part from you guys. I now need the instruction of how to install this part. It looks like some pieces will need to be removed to inable me to install the screw. can you provide me with a diagram or how to instructions?
Thanks,
Brad
  #2 (permalink)
Old 03-31-2011, 07:56 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Thanks,
Brad
Brad,
Could you supply a model number or the part number you orderred, so we can properly advise you.
Thanks,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 03-31-2011, 08:13 AM
Junior Member
Default
Yes, The model # is KHWS02RMT3 and the serial # is CST2411662
Thanks,
Brad
  #4 (permalink)
Old 04-01-2011, 06:36 AM
Senior Expert
Default
Thanks,
Brad
Brad,
Here are the instructions on replacing the baffles in your washer tub.
It's an excert from a post in the APP Repair Forum, and applies to your washer
If you have not already finished this repair, here's good news: it's EASY. Go ahead and order those parts. Get the kit with all three baffles -- its likely that the plastic tabs on more than one of them have been damaged, because Whirlpool apparently never installed the retaining screws that hold the baffles in place. It appears to be a common problem.
1) Remove the three screws on the back of the washer for the lid.
2) Remove the lid.
3) A black rubber hose enters the outer drum top and center near the front. Gently remove it from the drum.
4) Through the resulting hole, you can reach the exact spot for inserting the retaining screws for the baffles.
5) One by one, replace the baffles (they drop into place, then need a little force to slide them forward into place) and rotate the inner drum so that the retaining screw hole is visible below the opening in the top of the outer drum.
6) (Without dropping the screws into the space between the drums like I did ), install the screws to retain the baffles.
7) Repeat for the other two.
8) Replace the hose and the lid and its screws and rest assured that you did something that even the Whirlpool assemblers didn't do: install the baffle retaining screws.
Good Luck,
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 04-01-2011, 02:15 PM
Junior Member
Default
Thanks alot, I will give those instructions a try, does'nt sound to tough.
Brad
  #6 (permalink)
Old 04-01-2011, 02:39 PM
Senior Expert
Default
Brad
OK, We'll keep an eye out for your next post letting us know how things went.
Thanks,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Tumbler Baffles mobrien Dryer Repair 1 12-29-2010 08:21 AM
Installing baffles? Kenmore He3 Yogi3 Washer Repair 3 10-14-2009 04:07 PM
Maytag Dryer baffles Marty300 Dryer Repair 4 03-11-2009 08:54 PM
Loose Baffles on Atlantis frontloader CharlieHat Dryer Repair 1 11-14-2008 06:33 PM
Access To Dryer Baffles ronwapiti Dryer Repair 3 11-10-2008 12:55 PM
