What level will stop filling on small and med settings only. Large and x-large settings will fill and over flow. Tube and switch I presume....but thinking that since it works on 1/2 the levels might be something else.. Any help would be great. Thanks in advance for your time
On empty washer disconnect the air pressure hose from the water level switch. Blow some air through the hose to make sure it is clean. Reconnect the hose and give it a try. If the problem is still exist, replace the water level switch. - The water level switch Part number: AP4024032
Originally Posted by: Gene On empty washer disconnect the air pressure hose from the water level switch. Blow some air through the hose to make sure it is clean. Reconnect the hose and give it a try. If the problem is still exist, replace the water level switch. - The water level switch Part number: AP4024032
Thanks for your help again!!!
