maytag atlantis will drain, and agitate, will not spin...need help. Single mom with three kids really needs this to work. :(
the motor sounds like it is working only it is not spinning. Please advise. Lisa Originally Posted by: Gene
Lisa, Tilt the washer back. Remove and check the belt. Check how freely the pump pulley is moving in both directions. Check how is the drive pulley moving in both directions. Remove the front panel and check how is the motor moving on the plate. - The belt Part number: AP4029079
