Discuss
Cold Water only in Soak Cycle
 in
Washer Repair
Hi All, The other night i needed to pull the dryer drum out so I could get some debris out
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Cold Water only in Soak Cycle
  #1 (permalink)
Old 01-05-2009, 05:39 PM
Junior Member
sn8khd28 is on a distinguished road
Default Cold Water only in Soak Cycle
Model Number: 41794802301   Brand: Kenmore   Age: 1 - 5 years
Hi All,
The other night i needed to pull the dryer drum out so I could get some debris out that was wedged behind it.
This is a stacked all in one unit... so I had to pull the control panel out to take out the drum.
I put it back together and all of a sudden I get no cold water for wash cycles but I get cold water in the Soak option.
Any ideas would be greatly appreciated the switch I am figuring it is is $90 from sears so I hate to buy that if it is not needed.
TIA
Ads By Google
Related Models
Kenmore 41794802301 LAUNDRY CENTER
Kenmore 41794812300 LAUNDRY CENTER
Kenmore 41794812301 LAUNDRY CENTER
Kenmore 41794814300 LAUNDRY CENTER
Kenmore 41794814301 LAUNDRY CENTER
Kenmore 41794862300 LAUNDRY CENTER
Kenmore 41794862301 SEARS/LAUNDRY CENTER
Kenmore 41794872300 LAUNDRY CENTER
Kenmore 41794872301 SEARS/LAUNDRY CENTER
Kenmore 41794988101 AUTOMATIC WASHER
Kenmore 41794988110 AUTOMATIC WASHER
Kenmore 41794988801 AUTOMATIC WASHER
Kenmore 41794988810 AUTOMATIC WASHER
Kenmore 41797802790 LAUNDRY CENTER
Kenmore 41797802791 WASHER/DRYER
Kenmore 41797802792 LAUNDRY CENTER
Kenmore 41797804790 LAUNDRY CENTER
Kenmore 41797804791 WASHER/DRYER
Kenmore 41797804792 LAUNDRY CENTER
Kenmore 41797862790 LAUNDRY CENTER
Kenmore 41797862791 WASHER/DRYER GAS LAUNDRY CENTER
Kenmore 41797862792 LAUNDRY CENTER
Kenmore 41797864790 LAUNDRY CENTER
Kenmore 41797864791 WASHER/DRYER
Kenmore 41797864792 LAUNDRY CENTER
Kenmore 41798702890 LAUNDRY CENTER
Kenmore 41798702891 LAUNDRY CENTER
Kenmore 41798702892 LAUNDRY CENTER
Kenmore 41798802890 LAUNDRY CENTER
Kenmore 41798802891 LAUNDRY CENTER
Kenmore 41798804890 LAUNDRY CENTER
Kenmore 41798804891 LAUNDRY CENTER
Kenmore 41798862890 LAUNDRY CENTER
Kenmore 41798862891 LAUNDRY CENTER
Kenmore 41798864890 LAUNDRY CENTER
Kenmore 41798864891 LAUNDRY CENTER
Kenmore 41798988100 ELECTRIC DRYER
Kenmore 41798988110 ELECTRIC DRYER
Kenmore 41798988120 ELECTRIC DRYER
Kenmore 41798988130 ELECTRIC DRYER
Kenmore 41798988140 ELECTRIC DRYER
Kenmore 41798988150 ELECTRIC DRYER
Kenmore 41798988800 ELECTRIC DRYER
Kenmore 41798988810 ELECTRIC DRYER
Kenmore 41798988820 ELECTRIC DRYER
Kenmore 41798988830 ELECTRIC DRYER
Kenmore 41798988840 ELECTRIC DRYER
Kenmore 41798988850 ELECTRIC DRYER
Kenmore 41798989100 GAS DRYER
Kenmore 41798989110 GAS DRYER
Kenmore 41798989120 GAS DRYER
Kenmore 41798989130 GAS DRYER
Kenmore 41798989140 GAS DRYER
Kenmore 41798989150 GAS DRYER
Kenmore 41798989800 GAS DRYER
Kenmore 41798989810 GAS DRYER
Kenmore 41798989820 GAS DRYER
Kenmore 41798989830 GAS DRYER
Kenmore 41798989840 GAS DRYER
Kenmore 41798989850 GAS DRYER
Kenmore 41799160100 LAUNDRY CENTER
Kenmore 41799160110 LAUNDRY CENTER
Kenmore 41799160120 LAUNDRY CENTER
Kenmore 41799160130 LAUNDRY CENTER
Kenmore 41799160800 LAUNDRY CENTER
Kenmore 41799160810 LAUNDRY CENTER
Kenmore 41799160820 LAUNDRY CENTER
Kenmore 41799160830 LAUNDRY CENTER
Kenmore 41799165100 LAUNDRY CENTER
Kenmore 41799165110 LAUNDRY CENTER
Kenmore 41799165120 LAUNDRY CENTER
Kenmore 41799165130 LAUNDRY CENTER
Kenmore 41799165800 LAUNDRY CENTER
Kenmore 41799165810 LAUNDRY CENTER
Kenmore 41799165820 LAUNDRY CENTER
Kenmore 41799165830 LAUNDRY CENTER
Kenmore 41799170100 LAUNDRY CENTER
Kenmore 41799170110 LAUNDRY CENTER
Kenmore 41799170120 LAUNDRY CENTER
Kenmore 41799170800 LAUNDRY CENTER
Kenmore 41799170810 LAUNDRY CENTER
Kenmore 41799170820 LAUNDRY CENTER
Kenmore 41799175100 LAUNDRY CENTER
Kenmore 41799175110 LAUNDRY CENTER
Kenmore 41799175120 LAUNDRY CENTER
Kenmore 41799175800 LAUNDRY CENTER
Kenmore 41799175810 LAUNDRY CENTER
Kenmore 41799175820 LAUNDRY CENTER
Kenmore 41799180100 GAS AND ELECTRIC LAUNDRY CENTER
Kenmore 41799180110 LAUNDRY CENTER
Kenmore 41799180120 LAUNDRY CENTER
Kenmore 41799180800 GAS AND ELECTRIC LAUNDRY CENTER
Kenmore 41799180810 LAUNDRY CENTER
Kenmore 41799180820 LAUNDRY CENTER
Kenmore 41799185100 LAUNDRY CENTER
Kenmore 41799185110 27" LAUNDRY CENTER
Kenmore 41799185120 LAUNDRY CENTER
Kenmore 41799185800 LAUNDRY CENTER
Kenmore 41799185810 27" LAUNDRY CENTER
Kenmore 41799185820 LAUNDRY CENTER
Kenmore 41799190100 LAUNDRY CENTER
Kenmore 41799190110 27" LAUNDRY CENTER
Kenmore 41799190120 LAUNDRY CENTER
Kenmore 41799190800 LAUNDRY CENTER
Kenmore 41799190810 27" LAUNDRY CENTER
Kenmore 41799190820 LAUNDRY CENTER
Kenmore 41799195100 LAUNDRY CENTER
Kenmore 41799195110 LAUNDRY CENTER
Kenmore 41799195120 LAUNDRY CENTER
Kenmore 41799195800 LAUNDRY CENTER
Amana 418.000 Mwave - Family Size (60 Hz)
Amana 418.001 Mwave - Family Size (60 Hz)
Amana 418.002 Mwave - Family Size (60 Hz)
Amana 418.003 Mwave - Family Size (60 Hz)
Amana 419.000 Mwave - Family Size (60 Hz)
Magic Chef 41DA-3GKLW Range - F/s Cont Clean Gas
Magic Chef 41DB-3GKLW
Magic Chef 41DG-3GKLW
Magic Chef 41DN-3GKLW Range - F/s Cont Clean Gas
Magic Chef 41E -3GKLW
  #2 (permalink)
Old 01-06-2009, 03:36 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Kenmore is a pain to get technical info but by the sound of it you should not need any parts.
Since it worked before you took it apart odds are high that all you have is a loose wire somewhere
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No cold water and no rinse cycle jhead Dishwasher Repair 1 02-22-2010 08:03 AM
Kenmore 70 Series Washer - no cold water, weak spin cycle? PHRoberts Washer Repair 3 01-16-2010 04:28 PM
Soak Cycle garmen Washer Repair 2 09-23-2009 07:10 PM
no cold water on cold/cold cycle rpbmd Washer Repair 1 08-28-2009 10:04 AM
Spining cycle let clothes soak and wet ojsesiul@yahoo.com Washer Repair 1 04-06-2009 06:05 PM
