My washing machine will end the cycle 'Sometimes' with it full of water. I then have to dial to spin to complete the wash. I have a three button switch that says Super wash, Extra rinse, Cancel. It most always is on cancel. Will replacing this switch fix my problem?
I think the problem is in the timer. Your pump is connected by the belt to the motor, and if the motor is turning the tub to spin the water will drain out through the pump. I am guessing that the machine does not spin at all, and the timer just goes to the end of the cycle, with the process stopped after the wash cycle.
Check the wiring to the motor, but if that is ok I think replacing the timer should solve your problem.
Originally Posted by: sidfink43 I think the problem is in the timer. Your pump is connected by the belt to the motor, and if the motor is turning the tub to spin the water will drain out through the pump. I am guessing that the machine does not spin at all, and the timer just goes to the end of the cycle, with the process stopped after the wash cycle.
Check the wiring to the motor, but if that is ok I think replacing the timer should solve your problem. Thank you for that reponse. The problem is only intermitant. It does spin most of the time, just occasionaly will it be full of water when the timer gets to stop.
Right, that is why I think it is electrical rather than mechanical.
