Discuss
whirlpool duet error code FH
 in
Washer Repair
machine appears to fill normally , starts to tumble ,then after a couple of minutes stops +reads fh . i can get
Appliance Repair Forum > Appliance Repair Help > Washer Repair » whirlpool duet error code FH
  #1 (permalink)
Old 01-05-2009, 12:49 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default whirlpool duet error code FH
Model Number: glw9200lwo   Brand: Whirlpool   Age: 1 - 5 years
machine appears to fill normally , starts to tumble ,then after a couple of minutes stops +reads fh . i can get it to drain completley+ spin normally +finish cycle. i see no visual problem with water valve /how high should waterfill? should it fill past baffle fins in drum?. i was told water valve or flowmeter maybe problem . what is test for flow meter? if water valve or flow meter is ok , might it be pressure switch? by what i am telling you can you determine if any of these parts are suspect? nobody i spoke to seems to think ccu board is an issue.thanks
Related Models
Whirlpool GLWA6900W0
Whirlpool GLWA6900W1
Whirlpool GLWA6900W2
Frigidaire GLWS1233AQ1 Washer - Frig Gallery
Frigidaire GLWS1233AQ2 Frigidaire/washer
Frigidaire GLWS1233AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1233AS1 Washer - Gallery
Frigidaire GLWS1233AS2 Frigidaire/washer
Frigidaire GLWS1233AS3 Frigidaire/washer
Frigidaire GLWS1339CC0 Frigidaire/washer
Frigidaire GLWS1339CS0 Frigidaire/washer
Frigidaire GLWS1339CS1 Frigidaire/washer
Frigidaire GLWS1339EC0 Frigidaire/washer
Frigidaire GLWS1339EC1 Frigidaire/washer
Frigidaire GLWS1339ES0 Frigidaire/washer
Frigidaire GLWS1339ES1 Frigidaire/washer
Frigidaire GLWS1349AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1349AS1 Washer - Frig Gallery
Frigidaire GLWS1649AS0 Washer - Frig Gallery
Frigidaire GLWS1649AS1 Washer - Frig Gallery
Frigidaire GLWS1649AS2 Frigidaire/washer
Frigidaire GLWS1649AS4 Frigidaire/washer
Frigidaire GLWS1749AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1749AS2 Washer - Frig Gallery
Frigidaire GLWS1749AS4 Frigidaire/washer
Frigidaire GLWS1749AS5 Frigidaire/washer
Frigidaire GLWS1939AS0 Frigidaire/washer
Frigidaire GLWS1939AS1 Frigidaire/washer
Frigidaire GLWS1979AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1979AS2 Washer - Frig Gallery
Frigidaire GLWS1979AS3 Frigidaire/washer
Frigidaire GLWY1343AS0 Frigidaire/washer
Frigidaire GLWY1343AS1 Frigidaire/washer
Whirlpool GLXA6900W0
Whirlpool GLXA6900W1
Whirlpool GLXA6900W2
Whirlpool GLXA6900W3
Gaggenau GM104-710
Gaggenau GM104-714
International GM1110PRW Range - F/s Std Gas
Gaggenau GM215-721
Gaggenau GM215-760
Gaggenau GM215-761
Gaggenau GM286-710
Gaggenau GM286-720
Gaggenau GM286-760
Gaggenau GM288-710
Gaggenau GM288-714
International GM3110MPAW Range - F/s Std Gas
International GM3110MXAW Range - F/s Std Gas
International GM3110PRAM Range - F/s Std Gas
International GM3110PRWM Range - F/s Std Gas
International GM31113WAM Range - F/s Std Gas
International GM31113WAV Range - F/s Std Gas
International GM3111GXAW Range - F/s Std Gas
International GM3111SXAW Range - F/s Std Gas
International GM31211XAW Range - F/s Std Gas
International GM3167WUA Range - F/s Std Gas
International GM3167WUV Range - F/s Std Gas
International GM3210MXAW Range - F/s Cont Clean Gas
International GM3211GXAA Range - F/s Cont Clean Gas
International GM3211GXAW Range - F/s Cont Clean Gas
International GM3211SXAA Range - F/s Cont Clean Gas
International GM3211SXAW Range - F/s Cont Clean Gas
International GM3216WRWM Range - F/s Cont Clean Gas
International GM32211XAW Range - F/s Cont Clean Gas
International GM3267WUAM Range - F/s Cont Clean Gas
International GM3267WUWM Range - F/s Cont Clean Gas
International GM3267XUA Range - F/s Cont Clean Gas
International GM3267XUAM Range - F/s Cont Clean Gas
International GM3267XUW Range - F/s Cont Clean Gas
International GM3267XUWM Range - F/s Cont Clean Gas
Gaggenau GM335-760
Maytag GM3468XUW-X Range - S/c F/s Gas
Maytag GM3468XUWX Range - S/c F/s Gas
International GM3510PRW Range - F/s Std Ele
International GM3531WUV Range - S/c F/s Ele
International GM3531WUW Range - S/c F/s Ele
International GM3631XUA Range - F/s Std Ele
International GM3631XUW Range - F/s Std Ele
International GM3862XUW Range - S/c F/s Ele
International GM3868XUA Range - S/c F/s Ele
International GM3868XUW Range - S/c F/s Ele
Maytag GM4151WTA Range - F/s Std Gas
Maytag GM4151WTW Range - F/s Std Gas
Maytag GM4251WTA Range - F/s Cont Clean Gas
Maytag GM4251WTW Range - F/s Cont Clean Gas
Whirlpool GM8131XEB0
Whirlpool GM8131XEB1
Whirlpool GM8131XEQ0
Whirlpool GM8131XEQ1
Whirlpool GM8155XJB0
Whirlpool GM8155XJB1 Convection Microwave Oven
Whirlpool GM8155XJB2 Convection Microwave Oven
Whirlpool GM8155XJQ0
Whirlpool GM8155XJQ1 Convection Microwave Oven
Whirlpool GM8155XJQ2 Convection Microwave Oven
Whirlpool GM8155XJT0
Whirlpool GM8155XJT1 Convection Microwave Oven
Whirlpool GM8155XJT2 Convection Microwave Oven
Gaggenau GM915-710 UC/06 (FD 7710-7912)
Gaggenau GM915-710 UC/11 (FD 7912-8003)
Gaggenau GM915-710 UC/12 (FD 8003-)
Gaggenau GM926-710 UC/06 (FD 7710-7912)
Gaggenau GM926-710 UC/11 (FD 7912-8003)
Gaggenau GM926-710 UC/12 (FD 8003-)
Whirlpool GMA
Whirlpool GMC275PDB0
Whirlpool GMC275PDB07 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC275PDB08 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC275PDB1
Whirlpool GMC275PDB2
Whirlpool GMC275PDB3
Whirlpool GMC275PDB4
Whirlpool GMC275PDB5
Whirlpool GMC275PDB6
Whirlpool GMC275PDQ0
Whirlpool GMC275PDQ07 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC275PDQ08 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC275PDQ1
__________________
  #2 (permalink)
Old 01-05-2009, 06:32 PM
kayakcrzy kayakcrzy is offline
Senior Expert
APP Volunteer
kayakcrzy is on a distinguished road
Default
FH No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
• If there is water in the unit:
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Replace failed component
Tom
  #3 (permalink)
Old 01-05-2009, 07:46 PM
Senior Expert
APP Volunteer
Default
yes .i already have seen what you have sent me .this does not answer the questions i asked
__________________
  #4 (permalink)
Old 01-06-2009, 06:34 AM
Senior Expert
APP Volunteer
Default
Did you take the lower front panel off, and the pump will be right up front. Unscrew the pump cover, and see if there is not a bunch of stuff in the pump, causing it to slow drain. That is a big problem with that washer. Tom ApplianceEducator.com
  #5 (permalink)
Old 01-06-2009, 11:37 AM
Senior Expert
APP Volunteer
Default
there is nothing in pump. how do you check flow meter to see if it is ok? thanks
__________________
  #6 (permalink)
Old 01-08-2009, 06:31 AM
Senior Expert
APP Volunteer
Default
Pull the wires off the pump, and stick your meter leads inside, and see if you are getting power. I don't know what the resistance is supposed to read, maybe some of the other guy's out here, that like to piggy back on me here, have more time to find the manual to give you that answer. But, if it is not draining, I would replace the pump. If you bneed to look at a manual, go to service matters, and hit on job aids, and pull a manual on the duet, and it will tell you the perspective resistance it should read, but, it still might be bad if the impeller on the inside is damaged. Tom ApplianceEducator.com
  #7 (permalink)
Old 01-08-2009, 11:01 AM
Senior Expert
APP Volunteer
Default
there is no problem with pump. it pumps out normally. customer now tells me it reads hf intermitantly +stops after 2minutes in beginning wash. then at other times it will complete the entire wash as if there is nothing wrong, maybe there is a siphoning problem,i will try replacing flow meter
__________________
  #8 (permalink)
Old 01-08-2009, 05:51 PM
Senior Expert
APP Volunteer
Default
It is hard to tell from here. Sitting on my perch without my meter, does not help. Tom
  #9 (permalink)
Old 07-21-2009, 02:26 PM
ericsaraw ericsaraw is offline
Junior Member
ericsaraw is on a distinguished road
Default
Quote:
Misterfixall,
What was the solution to this problem. This is exactly what my Duet washer is doing. Any assistance will be greatly appreciated.
  #10 (permalink)
Old 07-21-2009, 03:44 PM
Senior Expert
APP Volunteer
Default
i replaced pump
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
WhirlPool Duet dryer with 'E1' error theprof Dryer Repair 2 01-13-2009 07:45 AM
Dreaded F06 error in Whirlpool Duet washer richappy Washer Repair 0 02-26-2008 05:20 AM
Whirlpool duet Error Code F30 mcjej@yahoo.com Washer Repair 0 11-24-2007 10:31 PM
error codes on whirlpool duet sport Thad Steele Washer Repair 1 11-02-2007 03:12 PM
Duet Sport F01 error Code vposton Washer Repair 2 09-15-2007 08:20 AM
